fuel pump replacement
Old Mar 22, 2013 | 06:35 PM
dieselphil's Avatar
dieselphil
well, I'm not left handed and I'm smart enough to let the engine cool down so I think I'll be ok. After I do it I'll let you know how much of a chump I am.
Old Mar 22, 2013 | 06:38 PM
dieselphil's Avatar
dieselphil
By the way, where's the best place to get a new pump? I usually shop at napa.
Old Mar 22, 2013 | 06:56 PM
fordpride's Avatar
fordpride
In the middle of summer in Louisiana it is.
I pulled up at my house opened the hood and started changing ther pump
Old Mar 22, 2013 | 06:57 PM
fordpride's Avatar
fordpride
Find the cheapest pump you can. The are all built by the same company.
Old Mar 23, 2013 | 04:30 PM
Action4478's Avatar
Action4478
Originally Posted by dieselphil
thanks, all this will help alot, I am new at this so bare with me, but I still don't know when the engine is at TDC. Also I read in another post that the banjo bolt on the turbo can get in the way. and that I may have to remove the fuel bowl to get at it.
There is a mark on the harmonic balancer that needs to be lined up with the pointer on the CPS .. Its impossible for the pump to pop up out of the intake ....The length of the tappet will not let it beyond its designed stroke...
Old Mar 23, 2013 | 05:49 PM
madpogue's Avatar
madpogue
^^^^^ That tells you when the _CRANK_ is at TDC for the #1 cylinder. Even if the lobe on the _CAM_ for the fuel pump were clocked so that when it's at its peak, it corresponds with #1 TDC on the crank, there's still only a 50/50 chance that, when the crank is at #1 TDC, the cam will be in the right position.
Old Mar 24, 2013 | 06:01 PM
Action4478's Avatar
Action4478
I'll respond to you like you responded to me ...(omitting a few facts )
How do you expect the pump to be pushed up out of the intake , when it is physically impossible ?Especially with a worn out pump that most likely has been corroded in place there for many years ...
Old Mar 24, 2013 | 06:07 PM
madpogue's Avatar
madpogue
The pump is in the block, not the intake. Whether the pump comes up or not, if the crank is in the right position, there's a 50/50 chance that the lobe on the cam will be all the way down rather than all the way up. This introduces the risk that the tappet will fall into the crankcase. And if the pump's arm is all the way down, the tappet should push the pump up IF the bolts are loose.
Old Mar 24, 2013 | 06:36 PM
mjunk1's Avatar
mjunk1
I'd like to think Mike was using "chump" in the kindest of all ways! Lol. But hope that I am not going to be the measuring stick for all pump replacement jobs. As I said, mine included a little more. I also did mine on a hot engine which helped because it was cold out. So the first 3 hours weren't so bad while the engine cooled.
Let us know how it turns out for you. I'm sure you'll do great.
Old Mar 25, 2013 | 12:57 AM
dieselphil's Avatar
dieselphil
this makes the most sense to me. As soon as I get my pump and fuel bowl gaskets and get them put in, I'll post some pics. Thanks to all for droppin' in.
Old Mar 25, 2013 | 08:55 PM
Action4478's Avatar
Action4478
So , physics doesn't apply here ..I can't believe I am wasting my time on this .
IT IS PHYSICALLY IMPOSSIBLE FOR THE TAPPET TO PUSH THE FUEL PUMP OUT OF THE ENGINE ...YOU MAY BE ABLE TO FEEL THE END OF THE STROKE ,NOTHING MORE . Have at it . A brand new pump installed 5 mins before will be hard pressed to pop up out of the motor . Keep spreading your BS if it makes you feel better .You seem to be picking & choosing the things you call me out on ..When there is a real issue , you don't have it . Have you ever wondered why all of the real techs have left ? You are one of the reasons ...Have at it PW...
Old Mar 26, 2013 | 12:26 AM
dieselphil's Avatar
dieselphil
Now, now. There's no need to get ugly here, we all just trying to help eachother out.
be cool.
Old Mar 26, 2013 | 12:30 AM
  #28
dieselphil's Avatar
dieselphil
I'm picking up my pump tomorrow. I will try poping the pump with the motor, and we will have settled this like civilezed folk.
Old Mar 26, 2013 | 08:55 PM
  #29
Furniture Doctor's Avatar
Furniture Doctor
Fuel pump
I replaced mine last March when it was still quite cold. I bought a cheap set of wrenches from HF and made a bend in the 1 1/4" with the torch. Another thing I did was to use thin thread to hold the metal gasket on the banjo bolt. The job is not difficult but can be a PIA.
Old Mar 27, 2013 | 12:46 PM
  #30
dieselphil's Avatar
dieselphil
well, I $%$%&ing did it. I drop the tappet into the block. It fell completely out of reach and sight. what the hell do I do now? help!
