<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start -->Hey gang,I have a 98 Mountaineer which was a great lil car,until recently.It seems when the car is driven for 20 min. or so,and I shut it down and then try to start it after a few minutes,it wont start,and yet after leaving it sit for about an hour or so it will start up ! Any suggestions ? Thanks in advance..................... Jim
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- edit note -->
Sounds like pretty common symptoms of a failed fuel pump. Eventually it will get to a point where even after sitting it won't restart. You could confirm a lack of fuel pressure is the issue with a fuel pressure gauge and a multimeter/test light if so inclined. Often a fuel pump that is starting to fail will gradually get louder outside the vehicle. Have you noticed recently that when the vehicle is running there is a rather noticeable whine from the middle or rear of the vehicle?
When you turn the key to the ON positon, you should hear the fuel pump prime for about 2 seconds. If you don't hear that, then the pump is not engaging. Start by checking the fuel pump relay.
