My t-5 shifter
Old Mar 21, 2013 | 09:40 AM
Ryan Sigman's Avatar
Ryan Sigman
My t-5 shifter
I figured I would post how I used the stock s10 t-5 shifter in my 51 f-1.
This is pre weld mock up
Old Mar 21, 2013 | 11:31 AM
Tyler S's Avatar
Tyler S
Thanks for this Ryan! this is the same direction I am going in my 51. I have a T5 with an S-10 tail housing and S-10 shifter. Glad to see it works out ok.
Thanks! Tyler
Old Mar 21, 2013 | 05:53 PM
tinman52's Avatar
tinman52
Welder User
Looks good. I laid mine across the anvil and beat on it with a BFH (cold).
Didn't want to burn up the little plastic sleeve thingy by heating or welding. Straightened it out pretty good....
Old Mar 21, 2013 | 10:00 PM
52 Merc's Avatar
52 Merc
How is it for function? It looks like it may still be a bit short and you'd have to reach for it. Is it more comfortable than it looks? Other than that, it looks great.
Old Mar 22, 2013 | 11:45 AM
brain75's Avatar
brain75
Question, can you reach it with a seatbelt on? I mocked up mine before I cut off the original shifter from my crash box and welded the two together (wrapped the plastic sleeve in a wet rag and had a buddy keep an eye on things to make sure I didn't weld too much continuously or too fast. T5 shifter alone was a confirmed no go with a seatbelt for me.
I tweaked the curvature of the T5 with a BFH (little warmed up but not glowing) a little and then matted both of em below the boot height (I got a stock rubber boot from MACs).
I advise you to seriously consider the height and ability to use it without hunching over / with a seatbelt on before you progress forward.
As much work as it was to get the mated angles right I also have to caution be sure you don't hit the radio in 3rd gear, or interfere with the seat in 2nd & reverse (I need to tweak mine a little more cause it touches the seat in R - no pressure, but it touches)
Old Mar 22, 2013 | 09:36 PM
whitley's Avatar
whitley
I have a T5 in my 49 F-3. I cut both my stock shifter, and the T5 shifter, then welded them together. It put the stock **** right up where the old set up was.
Old Mar 23, 2013 | 01:15 PM
Ryan Sigman
I dont have any problem reaching it at all. I will say tis though, I'm 6'2" and long arms. May not be as comfortable for someone shorter than me.
Martin Torres
Large Truck
Feb 16, 2019 10:03 PM
SideWinder4.9l
Mar 8, 2013 10:30 PM
Caruso72
Sep 2, 2012 02:52 PM
masseysbronco
Jul 27, 2010 07:25 AM
TheRoadVirus
Feb 23, 2008 07:59 PM
