4r100 trans fluid options
Old Mar 20, 2013 | 10:45 PM
Boom48's Avatar
Boom48
I know the ford dealers either use Mercon or Mercon 5. I was contemplating using Swepco 714. Any thoughts???? Also Exactly how many Qrtz does the 4r100 hold? including the Torque converter???? Was also thinking about running a little bit deeper of a pan.
Swepco 714 link :
http://www.swepcolube.com/products/s...smission-fluid
Old Mar 21, 2013 | 12:44 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I am running a Derale deep pan on mine. Increased capacity to 23 qts. No idea on that lube you posted. I'm happy with the Mercon V.
Old Mar 21, 2013 | 05:43 AM
Tugly's Avatar
Tugly
If you want to keep the fluid variety down, Mercon V works in the transmission and the power steering pump.
Old Mar 21, 2013 | 05:57 AM
hammer65's Avatar
hammer65
Personally, I would not. Just my .02
Old Mar 21, 2013 | 06:05 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Mercon V here as well. I believe the stock tranny runs about 18 quarts. I don't remember exactly, but that seems to be what I remember.
Old Mar 21, 2013 | 06:29 AM
JOHN2001's Avatar
JOHN2001
Originally Posted by twg1966
Mercon V here as well. I believe the stock tranny runs about 18 quarts. I don't remember exactly, but that seems to be what ai remember.
18 sounds right from bone dry to full. I had my tranny rebuilt last year and if I recall right I bought 20 qts and had a couple to spare. I run amsoil, I'm not sure what was in it before the rebuild but amsoil seems to run warmer than whatever was in it.
Old Mar 21, 2013 | 09:25 AM
trekbasso's Avatar
trekbasso
Mercon V can't be beat. From what I have read deeper pans offer NO advantage over stock.
Old Mar 21, 2013 | 10:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Swepco 714 link :
Why would you want to run this fluid? It was not designed for this trans. You will need to run your own test program to see if it destroys your trans.
Also, why a bigger pan? What do you expect to gain besides a lighter wallet?
Old Mar 21, 2013 | 10:54 AM
Boom48's Avatar
Boom48
I would like to run this fluid because it has a great reputation and good company backing it secondly i plan on towing and wanted to have a lil extra fluid to prevent it from over heating. Thirdly why your badgering me on a public forum where i'm asking an opinions and thoughts is beyond me, was looking for thoughts and opinions not harassment. Thanks-
Old Mar 21, 2013 | 11:33 AM
JOHN2001's Avatar
JOHN2001
Mark is the guy that shuts everyone else up and tells us what we need to know not want to. Don't take his words harsh I would call him out resident expert... He helped engineer our transmissions and know what's best so I would listen to him before anyone else about your trans.
Old Mar 21, 2013 | 11:45 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Motorcraft Mercon V has performed well for me, even in modified transmissions. I regularly send a fluid sample to the lab for testing and they say the fluid is performing well.
As for the deep pan....it does nothing for cooling. I have an ATS deep finned aluminum pan on one of my trucks and it doesn't help cooling at all. All it does is cost me more during fluid changes. If you want to cool your transmission fluid, your money will be MUCH better spent on a 6.0 cooler in place of your OE unit.
Old Mar 21, 2013 | 11:46 AM
trekbasso's Avatar
trekbasso
And I was thinking if I had a dollar for everytime Mark answered this ?. He is just matter of fact in his ways. And smart.
Old Mar 21, 2013 | 12:02 PM
JMP E350's Avatar
JMP E350
That's not badgering....That advise from a FORD TRANSMISSION ENGINEER -
Go ahead .. Run whatever fluid ya like ! (A slight badgering!) haha
Old Mar 21, 2013 | 02:56 PM
DND58's Avatar
DND58
I see a lot of guys mention using merc v in the transmission and power steering. How about the transfer case?
Old Mar 21, 2013 | 03:24 PM
trekbasso's Avatar
trekbasso
Good question. If most are like me, never have touched it except when I first bought the truck and checked level, two years ago. Probably engage it 1-2 times a year. But I understand it takes atf, so Merc V.
