Clutch Problem
Clutch Problem
I have a 1960 f100 I've been restoring now for 6 1/2 yrs. and I'm about 85% complete. I had a 223 & replaced it with a 302.The truck came with a hydraulic clutch and I thought it would be easy to keep. However the hydraulic clutch is my issue. I had the original rod that went into slave cyl & into tranny fork, but with a 302 there's not a lot of room in this area. There is such a short distance from slave cyl. to tranny fork, I cut the old rod trying to make it work, And now the original is way to short. I know that I could make another one, and I have but I'm having trouble with the length that its supposed to be. I have looked in various books ;Dennis Carpenter, LMC etc,but they only list this rod for a 1966 & up.Has anyone had this problem or could I be missing parts, is there an easier solution? Please help, send pics if you have a different set up, Thanks for any responses,twr71
I had similar issues installing the jr cummins 6at in place of a 223. I ended up making a bracket that used the original ford slave cylinder. But for your application let me suggest this. Various manufacturers make a slave clyinder that mounts within the bell housing. It's actually like a hydraulic throw out bearing with no linkage at the 'slave/business' end. No rods, just a telescoping bearing assembly that has a hose going to it and it surrounds the tranny's input shaft. I have never seen or used one, but the guy who was trying to talk me into it says they work very well and available for many different engine/trans setups. I think the main disadvantage is pulling the tranny if the cylinder assembly should ever fail. Most likely summit racing will have something. Just sounds perfect for close clearance stuff like yours.
I had a machine shop make a bracket to mount to bell housing, and bell housing had a bolt hole available to mount this .
I have a 1960 F100 I've been restoring now for 6 1/2 yrs. and I'm about 85% complete. I had a 223 & replaced it with a 302.
There is such a short distance from slave cyl. to tranny fork, I cut the old rod trying to make it work, and now the original is way too short.
Applications: 1960 F100/850 (except 401/477/534 V8 engines) / 1961/62 F750/850 (except diesel engines) / 1963 F700/750.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653 (listed as C0TT-7A507-A).
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
Everything else got a hydraulic clutch in 1984, didn't matter what the M/T was. Hydraulic clutch used thru 1996 or 1997 (F250/350 460/7.3L diesel).
aikensj
06-26-2014 09:13 PM
mechelement
25
04-03-2014 07:55 PM
steamin441
02-17-2007 02:36 PM
sancochojoe
05-15-2005 08:38 PM
tmessenger
11-27-2001 10:42 AM
