Electrical problems
Old Mar 19, 2013 | 07:52 PM
davbeisner's Avatar
davbeisner
Electrical problems
Ok, I know I need new alternators. I've got both (I have the ambulance package in my truck) on my work bench, but haven't had time to put them in. I'm watching my FICM carefully and so far haven't dropped below 45V; mostly runs 47.5-48. It'll drop to 46.5 at crank and for the first couple minutes sometimes.
So, over the past couple months the truck has dropped to 8-9V for the first couple minutes after start, and then kicked up to 13.3-13.8V (I'm not hitting 14V which I'm told is because the alternators need to be replaced). As of yesterday, though, until the truck gets back up over 12V, none of the electronics work--windows, gauges, radio, etc. SGII still works but that's it. Any idea what's causing that?
I plan to replace the batteries when I replace the alternators, too... I've got a trailer painting and re-decking project I'm part way done with and should have done by the end of the week. Once that's done I'll hopefully be able to get to the alternators.
Truck is an '03 F-350, 02/03 build date.
Old Mar 19, 2013 | 08:14 PM
BLADE35's Avatar
BLADE35
Dave the problem is when you do see the FICM start droping volts it will be TOO LATE
Its killing all the electronics
dont drive it unless its 911
Old Mar 19, 2013 | 08:22 PM
davbeisner's Avatar
davbeisner
Gotcha... makes sense. I'll have to drive it tomorrow to get my freshly painted trailer into the shop before it rains (it's a gooseneck trailer and I don't have a gooseneck hitch in my other truck yet) but otherwise I'll park it till I can get the alternators done. Actually, since I'm in a crunch right now on time I may just take the alternators in to my shop with the truck tomorrow and have them do it for me. I already have to have them do a steering box for me...
Old Mar 19, 2013 | 09:38 PM
Yahiko's Avatar
Yahiko
Put the battery charger on it NOW so it will be as charged as it can get.
Sean
Old Mar 22, 2013 | 01:27 PM
davbeisner's Avatar
davbeisner
How long should a dual alternator replacement take? From the ford service book it looks easy, but the shop guy is telling me four hours...
Old Mar 22, 2013 | 05:54 PM
cheezit's Avatar
cheezit
well sounds good to me labor wise. it will take hime less then 2 to do it though
Old Mar 22, 2013 | 06:20 PM
davbeisner's Avatar
davbeisner
Cool, that's kinda what I was thinking... he said that in order to get at the lower one he had to remove the fan and drain the coolant... Looking at it myself, I don't get that. Is he right? The Ford Shop manual says nothing about all that... Just removing the fan shroud, removing the belts, and done.
Old Mar 22, 2013 | 06:31 PM
cheezit's Avatar
cheezit
to remove the shroud requres the above to be done
jspence105
Aug 4, 2014 12:38 AM
christaylor
Jun 10, 2014 07:48 PM
parker245
Texas Chapter
Feb 6, 2012 10:10 AM
nlemerise
18
Aug 3, 2008 12:28 PM
3Mike6
N. California Chapter
Nov 29, 2006 12:24 PM
