WANTED: Column floor plate
Old Mar 19, 2013 | 02:10 PM
salf100's Avatar
salf100
Anyone have a steering column floor plate that holds the rubber seal down, for a 1964 F100? Id like to buy one. Thanks!!
Old Mar 19, 2013 | 06:12 PM
P38fighter's Avatar
P38fighter
Here's how I made one. If the subtitles don't come through they are in my album.
If yours is the same as mine I could e-mail you the template.
Old Mar 19, 2013 | 06:51 PM
salf100's Avatar
salf100
Wow! Yours and mine must be twins!! I would really apreciate it. What did you use for the rubber seal?
916kustoms@att.net
Old Mar 19, 2013 | 07:34 PM
P38fighter's Avatar
P38fighter
Your e-mail is on the way. The seal is available from the usual suppliers, Macs, Carpenter, LMC, NPD etc. Or go to your local industrial supply house and by 1/8 thick rubber sheet 1 foot square. My store charged me 2 bucks for the rubber. Don't hesitate to contact me for more info if you need it.
Old Mar 19, 2013 | 07:38 PM
salf100's Avatar
salf100
Thanks a million!
Old Mar 20, 2013 | 03:36 PM
charliemccraney's Avatar
charliemccraney
Nice work on those plates!
A few years ago, the repro seals were incorrect, for my '61, anyway. The hole for the column is too low. This drawing illustrates the difference.
The upper hole is correct. The lower hole is not. The repro's have the lower hole. You can use the screw holes to correlate the location of your column to the correct gasket. You should also be able to tell from the remains of your old gasket as long as it has not completely turned to dust.
There is either another application that uses the repro seal, or they screwed up when they made it.
You can use it. It will pull the gasket up which will leave a gap below your column and eventually tear.
In this picture, it has not yet torn but you can see the gap. I got some material to make my own but haven't gotten around to it. I tried seals from 2 different places and they were the same. Don't ask me which places. At this point I don't remember.
Old Mar 20, 2013 | 03:47 PM
salf100's Avatar
salf100
Good to no. I don't have the old seal so this helps. All u have is hot air across the headers burning my feet!!
Old Mar 20, 2013 | 07:46 PM
P38fighter's Avatar
P38fighter
Thats why I made my own gasket....I wasn't satisfied with the repro fit.
Old Mar 20, 2013 | 08:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Steering Column Opening Cover Plate Seal - Not Serviced "improvise from inner tube" = 1961/64 F100/250 2WD/4WD; 1961/66 F350/1100; 1963/69 N/NT/T500/1000; 1967/69 F800/1000.
C5TZ-3513-A .. Steering Column Opening Weather Seal / 1965/66 F100/250 2WD & 1966 F100 4WD
Which one is repro'd?
Old Mar 20, 2013 | 11:06 PM
charliemccraney
Based on that, I'd say the one they came up with to replace it is incorrect.
However, I'd bet that the seal used on the assembly line was not "improvise from inner tube." If it were reproduced, it would be from that one.
Old Mar 21, 2013 | 07:41 AM
schoo's Avatar
schoo
Boy the rubber seals on mine do look like inner tub, markings and all I don't think a pic would come out or I'd take one
Old Mar 24, 2013 | 06:09 PM
charliemccraney
I made my seal today.
Mine on left, Repro (Or aftermarket) on right.
Mine on top of repro.
And FYI, there are at least 4 different sets of metal covers. I don't know how it breaks down. I'm pretty sure one has to do with the factory installed transmission. The rest, year maybe?
This is the one that is on my truck, also pictured a few posts above, painted and installed.
The top two are for some other application. The bottom is the remains of the one that was probably original to my truck. What is interesting is that you can see that the hole is bigger and shifted down on two of them, which includes my original. I'm not certain at this point, but I think the 3rd had the hole too high to work with my steering column which is why I didn't use it.
And these help illustrate the differences in hole dimensions and positioning.
Old Mar 24, 2013 | 09:18 PM
Faber's Avatar
Faber
Thanks for picks/info. Be dealing with myself soon
Old Mar 25, 2013 | 02:54 AM
salf100's Avatar
salf100
You think it be ok to cut a slit on the seal where the column goes through so I don't have to take the steering wheel off?
Old Mar 25, 2013 | 06:41 AM
P38fighter's Avatar
P38fighter
No - that defeats the purpose of the seal. It needs to be tight. 64 has a short steering shaft doesn't it? I think you can loosen your steering column support bracket and slide the column up enough to slip the seal on from the steering box end.
