6.0 Dieing Problems
Old Mar 19, 2013 | 01:47 PM
bigo1806's Avatar
bigo1806
6.0 Dieing Problems
Hey Guys I am new here, but I thought that since I have had no luck elsewhere figuring out this problem I have I would ask you guys your opinions.
I have a 2004 Ford F-250 6.0 diesel which runs great and I do my own
maintenance on but has a small problem. Some back round on the truck is I bought it second hand it has a AFE intake and 4" turbo back Silverline exhaust system along with the bully dog triple dog tuner and bully dog out look. I will be drive at any speed and the truck will have no throttle response , but the engine will go to idle and sometimes it is for a few seconds and I can let my foot of the throttle press on it and it is good to go. It will happen on cruise control as well where it will just cut out go to idle for a split second and with out turning off the cruise control it will just kick back on. Along with that it has cut out and gone to idle and I have had to pull over and then it is good to go by time I have gotten fully pulled over. This is a sporadic problem as well where it may happen twice in 10 miles and then never happen for months or weeks. Or it will also happen multiple times in a week. I took it to a local ford dealership and had them run a diagnostics test on the motor and they said that there was no abnormal codes. It doesn't through a indicator light on the dash either. I have totally un install the tuner and returned it to stock and it still has this problem. The dealership suggested a throttle position sensor so I replaced that as well. Still have the problem. I have checked volts to the FICM and they are all around the 48 volts and connections are solid. I know that the 04 have the O-ring style STC valve but everything I have heard with that is the truck will just die and not start again and the ford dealer ran it and looked at the pressures and it did not fluctuate in pressure much on the high pressure oil pump.
So that is what I have and am looking for anything ya'll may know of have experience with. It is all much appreciated thanks.
Old Mar 19, 2013 | 02:25 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Mar 19, 2013 | 05:55 PM
04badford's Avatar
04badford
try cleaning EBP and tube,next and pulling and cleaning EGR
Old Mar 19, 2013 | 06:40 PM
dlibson's Avatar
dlibson
Could also be an APP problem and you may need to replace the accelerator pedal.
coplin
112
Nov 7, 2019 08:50 PM
oristorob
Jul 17, 2013 02:59 PM
magnessqh
16
Apr 8, 2007 03:53 PM
Dan Robertson
1983 - 2012 Ranger & B-Series
Oct 23, 2005 06:26 AM
JD Dixon
Sep 21, 2004 09:12 PM
