New Grille Guard
Old Mar 21, 2013 | 10:39 PM
Ryan0214's Avatar
Ryan0214
Originally Posted by CJM8515
Build some heavy duty brackets, one big pothole and its going flying.
Na, maybe another day when I'm bored and need something to do, but my friends and I made a few adjustments for it to sit up higher and made it a bit more sturdy. Its held on just fine.
Old Mar 22, 2013 | 01:50 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by 1993_f350_2013
[IMG][/IMG]
how would this cause more damage
For things like deer etc those are usually good to have, but thats it. In a small accident they can cause far more damage to the truck than a stock bumper. I'd rather have a bent bumper and small front end damage than a bent frame and destroyed radiator support.
Old Mar 22, 2013 | 04:28 AM
Bob Gervais's Avatar
Bob Gervais
Needs one of these:
Old Mar 22, 2013 | 12:00 PM
1993_f350_2013's Avatar
1993_f350_2013
a small accident would probably not be enough to bend the frame of a ford with one of the big replacement bumpers on it but how would you destroy the radiator support with one of them on there compared to a stock vehicle
Old Mar 22, 2013 | 12:27 PM
1993_f350_2013
Old Mar 22, 2013 | 02:13 PM
GBuckert's Avatar
GBuckert
...how would you destroy the radiator support with one of them on there compared to a stock vehicle
The one's I've seen with bent frames are usually hit higher on the grille guard and it looks kinda like the guard itself works like a lever and bends the frame horns up. In those it's enough to bend the top into the radiator support, but that radiator support was probably getting messed up even without the guard.
On the other hand, the only ones that I've seen in the shop are rigs that require body work. They're mostly highway speed related hits.
Old Mar 22, 2013 | 02:30 PM
1993_f350_2013
ahhh i see!!
Old Mar 24, 2013 | 06:40 PM
Ryan0214's Avatar
Ryan0214
Got some 3/16" steel, its probably a 4ft piece so me and my buddy are going to cut it into four pieces and double them up for the bracket coming straight from the bumper brackets. The only reason the grille guard is sagging forward is because the original bracket we used was just a cheap aluminum one from ace hardware, it seemed sturdy enough when I bought it, but with the weight of the grille guard on it, it flexes enough to sag the entire guard. I figure 3/8" of steel will be enough to keep it from sagging.
Old Mar 25, 2013 | 12:07 AM
TexasGuy001
I'm not trying to say it would be highly likely to happen. However, Since the bumper and gaurd are probably stronger than the rest of the front end, the truck becomes the weak point, and the bumper pushes back into everything else.
Old Mar 25, 2013 | 11:41 AM
1993_f350_2013
very true very true
Junx69
May 4, 2012 03:28 PM
xc4jokestomper
26
Dec 27, 2010 09:24 AM
JeremyG
27
Nov 30, 2008 01:27 AM
cpettymore7777
Nov 11, 2008 10:35 AM
jplyon
May 28, 2006 07:41 PM
