grille guard
Old Nov 8, 2008 | 07:12 PM
cpettymore7777's Avatar
cpettymore7777
grille guard
going to build a grille guard for a 95 f250 heavy duty. problem im having is that other than mounting it to the bumper i would like to mount the bottom of the guard on the frame also. i have leaf springs in the front and dont see anywhere i can mount it. any suggestions?
Old Nov 9, 2008 | 05:13 AM
TexasGuy001's Avatar
TexasGuy001
Take a look at how the Ranch Hand brackets are made. There is a angled bracket that goes under the bumper and a plate that goes behind the bumper.
Maybe someone has a picture of this. I used to have a Ranch Hand but don't have any pictures of the brackets.
Old Nov 9, 2008 | 05:15 AM
TexasGuy001
This is the type of grille gaurd I am talking about. There is a bracket that goes throught the air dam right next to the fog light. Your F250 doesn't have the air dam so you won't have to deal with that.
Old Nov 9, 2008 | 06:42 PM
cpettymore7777
sounds like that will work. do you know how big the plate is? i will do some measuring and see what kind of plate i got laying around. thanks
Old Nov 10, 2008 | 01:51 AM
TexasGuy001
The plate actually mounted behind the bumper to the bumper bolts and the bolts going through the bumper on the outside edge of the upright push bars mounted to the plate as well as the angled bracket. I don't know if you can see them in the picture or not, but they are there. I think if I remember right is was something like 8x10 or so. Does that make any sense?
Old Nov 10, 2008 | 04:54 PM
cpettymore7777
sure does. thanks alot
Old Nov 11, 2008 | 10:35 AM
TexasGuy001
No problem. Post a pic of yours when you get it fabbed up.
