loss performance / boost
So, in conclusion, what possibly, besides the tranny, you guys think, i may have screwed up. I'm at the point, where I HAVE TO, pull vc's, inspect injector oil discharge, remove injector connection, 1 atta time, retorque all bolts down, along with removing all, go ahead and do doughnuts (even though no signs of soot anywhere)....i dunno guys, just want my truck back..
(she used to LIGHT the tires up, bang'n int o2nd, wit h20+ psi, STOCK).( could a bent pushrod, stuck intake, bad injector, low compression...etc, cause any of this). I'm hit'n the hydraulic store today, i got the parts list to build a diy comp test
As for throttle response, I would first look at the TPS. There is alot of dirt and dust n stuff that gets drug in and out on the drivers side. Try a cleaning first to see if that helps as well. Pull the sensor and hit with with an electronics cleaner. Let it dry for about 5 minutes then put it back in and give it a try.
Really need to get ur on a scanner. With the amount of friends i have with these motors, you'd think we can put the $$$ together and get one, but THEY have no problems...
You know, if someone close to Elsinore, i'm willing to drive on over just to have another set of hears and SOTP opinion, you'd be headscratching, trust me, lol...
When i first got her, and installed the boost gauge, that damn needle would bounce all over the place, then with redline unhooked, holysh^%ba%$s, i let off so it wouldnt set the CEL light...thats how FAST it responded.
Mind you, this new boost # is with redline unhooked. With it hooked up, WILL NOT achieve 11psi, PERIOD
Anyone, in my situation, would you pull the trigger on the AE or get the AeroForce gauge, and with the extra $$$ saved, invest in IPR? I plan on keeping her a LONG TIME, so sensors, regulators..etc eventually need replacing, right?
Aha! A clue! Bouncing boost! I've seen that... but you may not like the answer. I lost a seal on my intake plenum and I was very lucky to stumble upon it. Throwing more boost at it just probably ripped more of the RTV... if you have the same issue.
Aeroforce is nice, it's a great way to monitor things. If you just want to keep an eye on something and drive, AE is cumbersome. Can you see the backpressure, boost, and road during a WOT... and remember the trend? Can you monitor ICP, IPR, FIPW, and MFD at the same time? That's one of the benefits of AE... logging the PIDs you need to see, so you just focus on your driving and troubleshoot later. The trucks aren't getting younger, and the diesel rodeos will come more frequently... so I chose AE.
Ok, along with this topic, i'm now hav'n Tugitis. Going under the VC's AGAIN. I went out wednesday to remove JUST the d/s vc. Considering the fact, that side bang'n away. Upon removal, a visual inspection resulted in nothing. So, layed a level across the injetors, all is good/flat. So, from the photo help from f350-6, i torqued down the bolts. Low and behold, #2 ihdb, was at 3#, YES, 3#..
. All others at there respected range. 2 of the rocker bolts were bang'n, i'd say, at 16-18#'s, so fixed them. HOWEVER, i did forget to unplug each one, to see if it upset the idling. So now, i'm "strap'n on the chaps" and head'n in again. This time, removing p/s as well, and testing.1 thing i left out, that i think MUST take note and hopefully results in a "reason" is this....With the d/s vc removed and all bolts re-torqued, i fired up truck, and at idle, inspected oil discharge from injectors. ALL injectors were "flow'n" oil. You noticed the word, flow'n. Thats because it was doing just that, flow'n. Not a "squirt'n" oil discharge. No splashing of oil, fountaining out of the head assy, notta, nuth'n...just an easy flow "thru the park" type discharge. I ask now, does this constitute, to a problem? Nother reason why, p/s and d/s vc's are being removed AGAIN, ...thanks all.
17-18 inch-pounds on #3 (DS is even-numbered)? Eeewww.... Whichever injector that was, I suggest O-rings and copper washer on it - and so does the book. You could have a damaged copper washer and fuel O-ring. Driving with that over a number of miles is what led to my cup job. At least O-ring kits are cheap and available at the stealership. I made an O-ring removal tool by grinding the handle of a toothbrush to a flat end... to prevent marring anything important.
Tugitis is a precurser to broke-itis. You'd better treat it quick. Take two VC lifts and call me in the morning.
It was 3lbs on the ihdb..(injector hold down bolt) which should be at 10lbs.
Buddy just became MIA on this project, so going in SOLO....
I did 200miles yesterday, so i'll recheck the bolts and see if any, any worked loose. i'll try to re-post later the outcome...
I only found 1 decent "oil discharge" vid to compare to, and if hpop plays a role into discharge factor, then i guess i cant go off of that, if it has anything different then stock in there. If stock, then mines' not "relieving" like it should then, cuz those injectors were squirt'n gooood.
Gonna get parts tomorrow for hpop idling testing, whats a good # psi at idle?
Today, i'll go fishing for diy parts to test hpop at idle. Also, gonna stop at local hardware store to rig up leakdown testing items, to ISOLATE potential areas...IC leak test only, aft IC to heads leaktest only..etc.
Maybe, middle of next week, i'll purchase the ford sealant to redo the plenums, just for the 'because". I gotta get into the valley anywho, to plumb some new crap on wvo related matters. Them plenums, is it possible to run a blade underneath to help with removal, or once bolts are removed its a matter of lifting up? They look to be made of stamped material. Would hate to bend/distort, and then gotta fish for new one, cuz them Clay plenums, sure look purdy.
Edit! The truck runs much better but like you I still feel I have a boost or drive leak in the system!! I can hit 30 psi with no problem and it wont move out of its way unless it cold. Then she will run like a STUCK PIG!!
Chet
I apparently dropped/lost the big o-ring between turbo and spider when I installed the 38R and it took awhile to find THAT leak, because I never looked there...
I would also suspect drive pressure leaks - look for soot on the pipes up at the collectors. The donuts will ALL leak eventually.
Low fuel pressure will also limit boost and giddy-up.
Even the little ScanGauge II is a great tool. It retails for $159 and will display (4 at a time) pretty much all of the parameters that AE or the AF Scangauge. Specifically, this gives you ICP, IPR Duty Cycle and EOT. It will also read/clear DTC's. Let Dave know I sent ya and he'll give you a good price on one.
Another option is the Torque App for Andriod phones. With a cheap bluetooth OBDII dongle and this $5 app, you can theoretically get the same data on your PHONE.
I know people using it on 7.3's and they say it works now (it didn't when I tried it last)...
