Running LEAN! 96 5.0
Old Mar 18, 2013 | 10:36 AM
FordYoungGun35's Avatar
FordYoungGun35
I'm gonna pull the codes this afternoon and gonna replace all 3 o2 sensors withing the next week
Old Mar 18, 2013 | 12:07 PM
RIKIL's Avatar
RIKIL
The narrowband is like a 3 position switch: high/low/off. It won't tell you how close you are to being wayyyyy rich or lean, it just reports as lean anything in the large range of what is considered lean AFR. A wideband will report all incremental values between extreme lean or rich so you know specifically where you're at.
You have 3 O2 sensors? That would make me think 2 are narrowband and 1 is wideband. If so, the wideband will have an output wire that reads anywhere from 0 to 5 volts. You can probe this wire while the motor is idiling and see if it changes when you rev the motor. That is what you should attach to a wideband gauge (and calibrate if necessary). It should read 5v when the O2 sensor is warmed up but motor not running. Then it'll change when you start the motor.
If you're going to monitor AFR, then get in there and connect this yourself so you can learn what it is you are using and how it works. It isn't much more difficult than wiring switches or the like. And you won't be at the mercy of the speed shop telling you what they did.
Old Mar 18, 2013 | 04:23 PM
Conanski's Avatar
Conanski
OBD-2 trucks have 2 upstream narrowband sensors and a 3rd after cat sensor that's is different but I believe it's still a narrow band sensor.. it's different in that it's designed to slowly float between it's upper and lower range instead of rapidly switching back and forth.
Old Mar 18, 2013 | 05:21 PM
FordYoungGun35
Pulled codes and it was secondary air injection so i dont know if that's relevant or not. But I can physically tell it's runnin lean because the throttle response is terrible and it doesn't go anywhere when I romp on it
Old Mar 18, 2013 | 09:13 PM
blkF250HD's Avatar
blkF250HD
The O2 sensor could be stuck lean, causing the computer to dump fuel. Poor MPG and performance will result.
Post-cat O2s are just like any other, the reason they move slowly or don't move at all is because the cat is using the stored oxygen to reduce the HCs and CO. The reason why the ECM commands the mixture to swing rich/lean is to provide oxygen for the cat, and to try to maintain as close to stoiciometry as possible.
Word of warning: There is a difference between an oxygen sensor and an air-fuel sensor:
Advanced air-fuel and oxygen sensor diagnosis - Automotive Service Professional
caiati
Feb 20, 2011 03:29 PM
tomtoc
1983 - 2012 Ranger & B-Series
Feb 19, 2007 06:58 PM
BLACK NITE
Apr 27, 2006 08:16 AM
UnderTakr
Kansas Chapter
Oct 1, 2005 02:34 PM
