Turning off interior lights
Old Mar 17, 2013 | 11:15 AM
gdwhetz31's Avatar
gdwhetz31
Hello,
We were at the drive in movies, (Yes, there are still a couple still alive around us) we had a comfortable spot in the back all set up. When the rear window was up, the interior lights stayed on. I couldn't find the valet switch to depress/turn them off. How can I turn off the interior lights while the back window is open. I have only had the Excursion for a month so I am still figuring it all out.
Thanks!
Old Mar 17, 2013 | 12:39 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
you have to add a switch, use the search function to find out which wires to tap into...
Old Mar 17, 2013 | 01:42 PM
mikeswae's Avatar
mikeswae
I don't know which model you have, but if you leave any of the doors (or back window) open the lights turn off automatically after 3 minutes on my 03 Limited.
There may be a relay you could add if you don't have it.
And get to the movie a few minutes early.
good luck
Old Mar 17, 2013 | 03:35 PM
gdwhetz31's Avatar
gdwhetz31
I have a '04X LT. I tried that. I left the back window open and after 15 minutes the lights were still on...ugh!
Old Mar 17, 2013 | 05:14 PM
Misky6.0's Avatar
Misky6.0
I added the "interior dome override" mod
On. My '05 the wire is behind the pass side
Kick panel. Running board lites are powered by
another feed, but i like shutting off ALL the
interior lights when needed.
Ran wires up to overhead between side swingout
window swirches like others did. Looks great.
Old Mar 19, 2013 | 08:23 PM
gdwhetz31's Avatar
gdwhetz31
Anyone know which fuse controls the interior lights? A quick fix would be to just pull a fuse, wouldn't it?
Old Mar 20, 2013 | 11:48 AM
5.4T's Avatar
5.4T
Looks like I got another mod to do
Old Mar 20, 2013 | 12:40 PM
covert's Avatar
covert
Same here. We head down to the Mesa drive-in in Pueblo all the time but this will be the first year with the Ex.
Old Mar 20, 2013 | 02:46 PM
neilc88's Avatar
neilc88
I also added the switch. The lights would stay on while packing for camping. And the drive in. Added switch is the answer.
keith56_cruz_cab
Mar 25, 2010 12:57 AM
richartdana44
Mar 29, 2007 07:58 AM
puppypower
Sep 18, 2006 02:50 AM
Crystal Moon
Sep 12, 2003 11:14 AM
hitechcpa
Feb 17, 2002 01:20 AM
