Performance Question
Is this normal operating perameters for this engine?
-Air filter was changed last summer.
-The turbo seems fine, no movement when shaken or pulled on, spins freely, no gouge marks from turbo fin strike.
-MPG's range from 12.5-14 empty, 10-12 pulling bass boat
I used to get in the neighborhood of 16-17 empty, on a consistant basis, and around 14-15 pulling trailers.. (loaded to about 10-15K)
Been fighting this issue for some time now.. I've done the boost leak check, up pipe leak ck, ebpv clean, changed oil at 5k everytime (Rotella syn for several yrs now) 192 deg thermostat. Truck starts easily, runs great empty, however it seems to be laboring when under a modest load (boat). (even a buddy mentioned he noticed it)....
I have a couple ideas, but don't know if I'm all wet or not..
***I've seen on other engines (not PSD's, tractors, school bus engines) which held in spec fuel pressure but were unable to provide needed volume. ****In fuel tank pickup screen full of crud. ***Wonder if wastegate is hanging / blowing open *** MAP sensor being bad
Hell, I don't know,,, just tired of the slight loss of pulling power and crap fuel econ, being Diesel isnt getting any cheaper. Before anyone asks, I fuel at same place, same pump, nearly every time.. and I know how to ck my mpg with a pencil...
But, I sincerely appriciate every logical suggestion you all have... I just hate going to the dealership.. Most of them can't diagnose a briggs and stratton lawn mower engine w/o having it a week and lot of dollars thrown their way...
It does have a superchip tuner tune installed... the lowest setting to change the fuel timing to get rid of off idle sluggishness... and, the numbers I've listed are the same on "Stock" or "Economy" super tuner tune...
Both were on level road: #1--- 4.4 Boost, 1546 ICP, 23.1 EBP, 24 IPR #2--4.7 BST, 1537 ICP, 22.8 EBP, 25 IPR
Boost reading may differ with different gauges and hose lengths and stuff. After hooking up my boost gauge I was only seeing 15-16psi as well. No boost leaks, good turbo.
