Modular V10 (6.8l)
V-10 Poor running under load
Old Mar 17, 2013 | 05:48 AM
knberberich's Avatar
knberberich
Exclamation V-10 Poor running under load
Hi i have a 1999 6.8 liter. It started running really poor about 2 weeks ago. I changed out the fuel filter, gas filter, air filter, spark plugs, 7 coils, mass airflow sensor. The truck is still running the same. It runs great at an ideal. When you start to drive it runs good for about 10-15 minutes the spitting & sputtering and i can't go over 1500 RPM'S. I shut the engine off for 30 seconds and it's cleared out for 10-15 minutes and back to spitting & sputtering again. Any ideas what what I should do next. Thank You.
Last edited by knberberich; Mar 17, 2013 at 06:18 AM. Reason: v10 poor running under load
Old Mar 17, 2013 | 06:19 AM
JWA's Avatar
JWA
Is it throwing any codes? Is the CEL on by chance?
Old Mar 17, 2013 | 11:33 AM
knberberich
I have code p0171 & p0174) Bank 1&2 both running lean
Old Mar 17, 2013 | 11:38 AM
knberberich
I have codes P0171 & P0174 both banks running lean. Yes the CEL is on.
Old Mar 17, 2013 | 11:41 AM
JWC 3's Avatar
JWC 3
Ck fuel pressure. Also ck for vac leaks and un meterd airflow .
Old Mar 17, 2013 | 11:49 AM
knberberich
Fuel pressure is right on. I have 33 psi with it not running & 27 psi when running
Old Mar 17, 2013 | 01:12 PM
BUNN MAN's Avatar
BUNN MAN
Fuel pressure numbers you have are too low.Shoud be no less than 32-35psi at running idle and 42-45 under load.Double check those numbers under the conditions listed and verify.
Old Mar 17, 2013 | 06:47 PM
knberberich
I did the fuel pressure test again. I have 26 PSI when the truck is in park running and when i put the truck in drive and run it up to 1500 RPM'S the pressure drops to 22 PSI. Could that mean i have a weak fuel pump.??
Old Mar 17, 2013 | 06:57 PM
JWC 3's Avatar
JWC 3
Yes that pressure is too low .
Old Mar 17, 2013 | 07:32 PM
knberberich
Does anyone no if the fuel pressure regulator goes bad will that make the fuel pressure go to low in the fuel rail.
Old Mar 18, 2013 | 06:41 AM
knberberich
Do I need to change the fuel pump.
Old Mar 18, 2013 | 12:35 PM
northwindone's Avatar
northwindone
Just from what I can remember from reading the V10 forums for the last couple of years it is more likely the fuel pump than the fuel pressure regulator.
You can either do it from below and drop the tank, or you can remove your bed and do it from above without removing the tank. I understand removing the bed is the easier route if you have a couple friends that can help you lift it off, but you will most likely have to cut some bed bolts and replace them since they like to seize.
Old Mar 18, 2013 | 01:22 PM
Wolfboro's Avatar
Wolfboro
Here is a method to test fuel pressure regulator:
(This is from V-10 forum archives posted by the moderator art k.);
"Should be 28-30 at idle, 38-40 with vacuum disconnected at the regulator.
Try that first, disconnect the vacuum at the regulator and watch the gauge. If it doesn't change, and there is vacuum on that hose, the regulator is obviously bad. "
Good luck,
Old Mar 18, 2013 | 05:50 PM
knberberich
Okay I think I found the problem. I dropped the fuel tank and found the 2 pump screens on pump we're so gummed up I can't believe it ran at all. I cleaned out the tank and installed new fuel pump. The truck runs like a raped ape. I think it runs as good as new knock on wood. Thank You
Old Mar 18, 2013 | 06:36 PM
JWC 3's Avatar
JWC 3
Glad you got it fixed . Thanks for posting the fix .
