Sponsored by: Real Truck
Please help !!
Old Mar 16, 2013 | 05:50 PM
joedielover's Avatar
joedielover
Please help !!
So I am going to look at a 4x4 99 f250 single cab 7.3 with 213k miles on it and the guy is selling it for 4500, but the tranny is having problems with downshifting, the complante is that it won't down shift and leaks a little trany fluid. I am a diesel tech in training and my guess is its loosing pressure and can't down shift would like some more thoughts before buying this please help.
Old Mar 16, 2013 | 07:12 PM
mikeismadness's Avatar
mikeismadness
Here a bump for ya. If its leaking fluid it could be a bad front seal, broken trans line, or a bad pan gasket. Some more details on where its leaking would help us out
Old Mar 16, 2013 | 08:35 PM
joedielover
Leaking for the front of tranny
Old Mar 17, 2013 | 12:48 AM
Ridenred333's Avatar
Ridenred333
Is there fluid above the pan if so then it may be a seal up towards the flexplate. If not then it would be from the the trans pan gasket.
Old Mar 17, 2013 | 12:50 AM
joedielover
But would that cause not be able to down shift?
Old Mar 17, 2013 | 12:59 AM
Ridenred333
I myself dont know that answer however it may not be related to the trans leakage causing the down shift issue. It could be a computer issue.. Just being honest with you.
Old Mar 17, 2013 | 01:22 AM
mikeismadness
The downshift could be a few things. I'd try and see if
It has tranny codes.
I'd also go into buying this truck thinking rebuild/replace. Just my .02
Dlras
Nov 19, 2017 07:01 PM
thunder74-79
1983 - 2012 Ranger & B-Series
Jun 28, 2012 07:30 PM
powerstroke6ltr
Oct 30, 2007 09:17 PM
ejb4x4429
Feb 7, 2003 09:59 PM
PATRICKA
Aug 20, 2002 02:46 PM
