Sponsored by: Real Truck
Checking spare tire pressure
Old Mar 14, 2013 | 08:42 PM
ATP Pilot's Avatar
ATP Pilot
Exclamation Checking spare tire pressure
New truck 2013 F250, I decided to check the spare tire pressure today and make sure the key etc...worked. Tire had only 50 psi from factory. My front is 60 and rear 70. So I took care of that.
My Question is....Why is the valve stem on the top where you can get to it with out lowering the tire? I've flipped the spare on another truck with no problems, has anyone flipped their spare or has information why not to?
Thank
Old Mar 15, 2013 | 07:14 PM
galaxie641's Avatar
galaxie641
I flip them down, my guess would be because of the very small chance road debris could hit and tear the valve stem off somehow with it down. It is good to make sure the jack works and run it up and down at least a few times a year though, so if you have to lower the tire to check the pressure that also gets done.
Old Mar 15, 2013 | 11:00 PM
JSolve's Avatar
JSolve
Curious as to why the unequal front/rear pressures? Mine came with 65lbs all around. Do you also have 20" rims with Michelins? With say 1500 lbs of weight in the bed how would you run them? Thanks in advance.
Old Mar 15, 2013 | 11:19 PM
cschannuth's Avatar
cschannuth
With the wheel flipped the wheel will hold water and rust. If your flushing the under side of your vehicle with water regularly (which you should) to prevent rust, there's a good chance water will collect in the wheel.
Old Mar 16, 2013 | 09:41 AM
ATP Pilot's Avatar
ATP Pilot
Now that makes sense. But...No road salt down here, don't go muddin and I don't have a boat, so I have never washed or had rust underneath.
Old Mar 16, 2013 | 09:44 AM
ATP Pilot's Avatar
ATP Pilot
18" rims and that is what the door sticker calls for. I have a much better empty ride with 60 psi in the rear and no TPMS light at that pressure.
The only real way to know about your pressure, would be stop by a truck scale, weight the truck for the axle weights and find the load/pressure chart for your size tires.
Old Mar 16, 2013 | 11:33 AM
meetre's Avatar
meetre
My truck says to keep the front at 55 psi and rear at 70 psi. I run at 60 psi up front and 65 psi on the rear. I do have E rated tires and this seems to be the best ride/tire wear/mpg spot for me.
edit: I do up the pressure in the rear for hauling and towing heavy weight. I keep my spare at 80 psi so I can adjust if needed.
onug
2015 - 2020 F150
Jul 16, 2019 09:26 PM
Sous
20
Jan 26, 2018 09:57 AM
jowilker
2004 - 2008 F150
Jul 31, 2012 04:15 PM
pdqford
Aug 26, 2008 01:17 PM
GTB
Mar 16, 2005 08:26 AM
