Sponsored by: Real Truck
E-350 Spare Tire Surprise
Old Mar 16, 2005 | 08:09 AM
GTB's Avatar
GTB
Cool E-350 Spare Tire Surprise
I have an 04 E-350 (6.0 diesel). Recently towing a boat to FL, I got a tire puncture in a construction zone (I-75) in south GA. When changing the wheel, I found that the tire iron doesn't fit in the spare tire release crank--it is too short. It took 20 minutes just to lower the spare! The tire iron hits the bumper with each 1/2 turn of the crank, requiring that it be re-inserted (a probing effort each time to get it into the recieving slot) again and again. I took my tire iron to a welding shop and had it lengthened by 3 inches on my nickle, no thanks to Ford engineering.
Old Mar 16, 2005 | 08:13 AM
camo4stealth's Avatar
camo4stealth
That's retarded. Not you, the dillweed at FORD that put the tire iron in that van.
Old Mar 16, 2005 | 08:26 AM
Lashlaroo's Avatar
Lashlaroo
There's a lesson here for the rest of us. Drop your spare tire with the supplied equipment in your driveway, on a nice sunny afternoon. clean it, run the tire pressure up to max, and put it back up. Max the tire pressure, because you don't know the load on your truck when you will need the spare. You can always let air out.
