fuel issues
Old Mar 13, 2013 | 02:11 AM
460tuff's Avatar
460tuff
Question fuel issues
i have a 86 dually with the 460 gas & a 4 barrel holly motorcraft carb recently had the flywheel replaced & starter ! now when i go to start my truck it wont stay running it just dies but starts rite back up ! problem also is whoever owned it before i did removed a lot of vac lines & the front gas tank does'nt work rite ! NEED HELP PLEASE ! I use my truck for my business & rite now cant afford to have some1else fix it that knows how to !
Old Mar 13, 2013 | 03:00 AM
6vChevyBelair235's Avatar
6vChevyBelair235
Make sure you check all the vacuum line condoms/covers and make sure they are still there and not split. I'm not much on Ford gassers, but if you have a vacuum advance, check the hose to that as well. Sometimes even the slightest leak can cause the dumbest problems.
When you say front gas tank, do you mean the front fuel bowl on the carburetor, or twin fuel tank??? Making sure we are still in the engine bay...
Old Mar 13, 2013 | 08:58 AM
subford's Avatar
subford
Sounds like a bad oil pressure switch or low oil pressure.
It could also be a bad fuel pump cut-off relay, tripped Inertia switch or a bad fuse.
Bad wiring could also do this.
Old Mar 13, 2013 | 10:50 AM
hotstuff's Avatar
hotstuff
could be the choke , choke pull off , low fuel delivery or idle solenoid
1bigbuilder
Apr 20, 2015 10:04 AM
azgunner
Aug 15, 2014 08:56 AM
83farmtruck
22
Jan 8, 2012 06:04 PM
Esgar
May 9, 2009 09:58 PM
tuffkiller
Aug 19, 2006 01:00 PM
