Catalytic Converter Help, Please!
On a 2006 F250 XL V8 5.4L Super Duty I am replacing the catalytic converter with a direct bolt on replacement product through Walker. The bolts that connect in front of the catalytic converter on the engine side I found out are recommended to be only used once and I purchased a set of replacement hardware. However how do you get the existing bolts off the mount to the exhaust manifold? It is tapered and rounded at the tip and I can't find a socket that works on it. Any suggestions?
In reply to JWC 3 comment
Well three out of the four total went back on correctly. The fourth was a problem and it stripped pretty bad. When I was able to remove the nut that was forcibly threaded on there I tried to see if I could manage a new nut on there and it got past the tip and just spins freely and isn't backing off. By blue wrench are you referring to channel locks? And do stud pullers work on tips that are flat on two sides and round on the other two? That is what the tip of the bolt looks like.
chillman88
07-28-2013 09:15 AM
Bobbys Big Red Rig
03-17-2013 04:58 PM
Fordenthusiasts
19
02-21-2010 07:19 PM
maddog72
01-05-2005 03:56 PM
