Instrument Cluster Default Setting
Old Mar 11, 2013 | 09:39 PM
soos76's Avatar
soos76
A few weeks ago I was making some upgrade changes to my Sync-My-Ride system for my new cell phone/bluetooth compatability. As some may know you have to have the vehicle idleing while doing this. Well up until this time, my dash display was always set for MPG monitoring. After I was finished with the sync process and ever since, my dash display is defaulted to the trailer display. Does anyone know how to get it back to the default
MPG monitoring display?
Old Mar 13, 2013 | 08:54 AM
bigdaddyII's Avatar
bigdaddyII
Use the arrow buttons on your steering wheel. Push to the left until all the options show up on the screen. Scroll to "Fuel Economy" and press "OK". then press right for the alternate economy screen.
Old Mar 13, 2013 | 11:10 AM
soos76's Avatar
soos76
Thanks, but that is a temporary fix which I have been doing all along but it does not fix the original problem. The problem is that whenever the truck is turned off and then restarted the display goes back to the trailer mode display. Before I did my phone sync my display was always the MPG display mode upon start up and that is where I would like it to be again.
Old Mar 14, 2013 | 10:40 PM
FireMe's Avatar
FireMe
Disconnect the battery for a few minutes. Glitches show up sometimes due to the way Sync works with the vehicle networks, and killing the power usually resets everything back to normal. We do this at the dealership more or less on a daily basis.
Old Mar 15, 2013 | 05:17 AM
MKEBoost's Avatar
MKEBoost
That's so odd that it acts like that. I thought that it would remain on whatever screen you last used. Let us know how you make out with the reset.
Old Mar 15, 2013 | 08:02 AM
howellt39's Avatar
howellt39
Do you have a trailer adapter plugged in or anything (7 spade to 4 pole or something like that?). Anytime my trailer is connected my display defaults to the trailer screen. Figured if you had an adapter back there maybe the truck thinks something is back there.
I keep an adapter plugged into my fifth wheel receptacle to power some of my "shadetree treasure".
BrandonA
Oct 10, 2018 04:23 PM
Nimrod
Apr 13, 2017 08:39 PM
rickfar
Escape & Escape Hybrid
Jul 31, 2012 07:52 AM
IT_Dude
Jan 3, 2011 10:53 AM
silverstreak70
Sep 28, 2009 11:21 PM
