86 compatible Engine
Old Mar 11, 2013 | 02:26 PM
Shanenathin's Avatar
Shanenathin
Question 86 compatible Engine
Hey guys. I'm back again this year to finish the work on my truck. Need to replace the engine entirely. (Very Long Story) So my question is, how new can I go up to in the 5.0 series before running into issues of needing to run all new computer wiring? Looking to get one by wednesday so a little urgent when you guys can...
1986 Ford F150
V8 5.0 motor
C6 Transmission
Old Mar 11, 2013 | 02:39 PM
Archion's Avatar
Archion
Veteran: Marine Corps
As long as you swap over your existing intake etc, then there should be no issue as long as you get it from a truck. Some of the later car HO units had a different firing order, but not insurmountable. The explorer motors would be the most difficult, head swap etc...
Old Mar 11, 2013 | 03:41 PM
Shanenathin
Thanks, I am only trying to find out because my buddy has a 1995 Ford Bronco with a V8 5.0 as well, his is always having computer issues. So I know my 86 being EFI has a simple computer so I kind of want to stick with that instead of having to run a whole new harness.
******** type="text/html" id="overlay_tmpl">
Old Mar 11, 2013 | 03:58 PM
Archion's Avatar
Archion
The only plugnplay would be 85-86 truck, other than that, you will need to swap your stuff on.
Old Mar 11, 2013 | 04:57 PM
Franklin2's Avatar
Franklin2
Yes remember you are only looking for a good base block/heads mechanical part of the engine. You will have to unscrew all the sensors and the other little stuff off your engine and transfer them to the "new" engine.
Old Mar 11, 2013 | 10:21 PM
lmarcoe's Avatar
lmarcoe
I happen to have a spare 302.... Heads recently done. This is an 86 with a C4 Tranny, edelbrock intake with a holley 4 BBL.
Engine is on my engine stand, Heads are in my basement.
Let me know if your interested.... Located in Wisconsin
glockerz94
Feb 2, 2020 10:01 PM
Creekside48
1978 - 1996 Big Bronco
Jun 22, 2018 09:55 AM
MeLikeFords
Engine Swaps
20
Apr 14, 2005 02:12 PM
flareside crazy
Jan 1, 2004 05:50 PM
