5.0 to 5.8 efi swap
5.0 to 5.8 efi swap
Hey guys I have an 86 Bronco that currently has a wore out 5.0 in it. I found a deal on a 5.8 out of a 91 F250. First question is will the harness on the 5.0 fit on the new engine? Second question is the new engine has a serp belt set up, which I’d like to keep, so the ac compressor is different. What hoses would I need to hook it up or would I have to have custom hoses made... and last of all.. with ac and no smog pump on the engine, does anyone know what belt I need?
the harness might work, I know 85/86 were the first 2yrs of ford efi on the broncos and the wiring pin out an so forth are different then 87+. the 5.0 computer wont run that motor very well so a complete wiring swap may be necessary or a fivology mass air swap being the better idea down the road perhaps. i have no idea regarding the other questions you have. good luck and take pics, this is a great swap though so don't get to discouraged.
jesusno2
07-08-2004 04:17 PM
