MPG DROP
Old Mar 11, 2013 | 01:39 PM
j4henry's Avatar
j4henry
MPG DROP
I have a 2010 f150 lariat with 33k miles, used to average 15-17 mpg all of a sudden it has dropped to 9-10. I keep oil changed regularly and air filter is new is there something I've missed with service on this thing???
Old Mar 11, 2013 | 05:34 PM
stephen.osborne1's Avatar
stephen.osborne1
I have noticed that the different blends of fuel from station to station cause my mileage to vary greatly. Perhaps you went to a different station, or perhaps the station you use changed their mix. Normally gas stations are switching from winter to summer blend about this time, and mileage gets better, not worse.
Old Mar 11, 2013 | 06:45 PM
Pool Runner's Avatar
Pool Runner
Check tire pressure, a low tire even if you can't physically see it will make the truck seem as if its driving in sand.
Also it could be clogged catalytic converters that have not tripped a CEL yet.
Transmission fluid change? Old fluid could cause the shift points to change slightly, yet enough to effect mpgs especially in the city.
Old Mar 11, 2013 | 07:42 PM
meborder's Avatar
meborder
that kind of mileage would be on the poor side even running e85. unless you got a slug of really bad fuel, i doubt that its the cause. FWIW, i just put about 100 miles on my work truck today and averaged about 16mpg running e30. this included a measurable amount of idle time and some interstate at 70mph.
that being said, switching to a different brand of fuel is an easy thing to try, so i'd start with that.
best bet beyond that point is to find an ODBII scanner than can read pending codes. that would indicate a problem that has showed up but not turned on the CEL yet.
Old Mar 12, 2013 | 10:45 AM
SuperDutyScaler's Avatar
SuperDutyScaler
my 2004 F350 with the 5.4 does this EVER winter. i go from 12-12.4 all summer months to last weeks mpg of 8.3 mpg! I figured by now it would be back to normal since the past two weeks its been in the fifties here in NJ..........
Old Mar 14, 2013 | 06:45 AM
j4henry's Avatar
j4henry
Well I dropped a k&n in it and ran some additive to fuel and we took a 300 mile trip averaging 18.2 that truck has never got more than 15...
Old Mar 15, 2013 | 05:21 AM
MKEBoost's Avatar
MKEBoost
My MPG also drops slightly in the cold weather. I attribute this to longer warm up times, sittin idle and occasional use of the 4 wheel drive.
Old Mar 15, 2013 | 07:44 AM
howellt39's Avatar
howellt39
I'd jack it up, rotate each wheel and make sure you aren't dragging a brake. I have to lube the slide pins on my 350 2X a year to keep them running free. Can rob some serious mileage left to their own devices, kinda like kids...
Old Mar 16, 2013 | 10:10 PM
j4henry's Avatar
j4henry
Well my wife fixed it she ordered a 10th anniversary jeep rubicon...
Old Mar 16, 2013 | 10:50 PM
ri_truck_guy's Avatar
ri_truck_guy
Sorry dude. My suggestion would have been a dragging brake as well.
Old Mar 18, 2013 | 09:18 AM
howellt39's Avatar
howellt39
I don't know if that's a "fix" but certainly made it go away for a while!
Old Mar 18, 2013 | 09:35 AM
gDMJoe's Avatar
gDMJoe
Other additional factors that affect winter MPG ...
  • ECM keeps the engine in its start-up warm-up loop longer.
  • tire pressure decreases due to colder temp's.
  • increased rolling resistance due to it taking longer to get-up to normal operating temperatures for ...
    • tires
    • transmission fluid
    • differential fluids
      etc., etc., etc..
  • extra weight in bed for traction. *Snow country issue.
-click- the pic'
Goth 150
< This space intentionally -blank- >
kel1306
Dec 21, 2014 05:57 AM
boats313
6.7L Power Stroke Diesel
Apr 5, 2012 06:37 PM
powerstrokinsmokin
Feb 14, 2008 08:13 PM
propertycare
Feb 5, 2008 09:28 AM
Schuby
Escape & Escape Hybrid
Oct 26, 2006 12:38 PM
