Stranded
Old Mar 10, 2013 | 07:25 PM
Chris 56 f6's Avatar
Chris 56 f6
Stranded
I am driving home in my 06 6.0 engine turned off pulling up to a stop sign!! Cranks fine ! Won't start back up. Batteries are fine! Was running fine up to it turned off! Any ideas?
Old Mar 10, 2013 | 07:34 PM
chetspencer's Avatar
chetspencer
Dummy plugs or standpipes, would be my first guess.
Old Mar 10, 2013 | 07:42 PM
mustang_309's Avatar
mustang_309
X2 what Chet said plus I will add a possible STC fitting. Try letting it cool down for an hour or so and try restarting it after it cools down.
Old Mar 10, 2013 | 07:46 PM
chetspencer
Yep, I forgot about the STC fitting.
Old Mar 10, 2013 | 09:01 PM
Chris 56 f6
Unhappy
What s a dummy plug and standpipe stp
Old Mar 10, 2013 | 09:04 PM
chetspencer
Part of the HPOP system, the o-rings fail. There are newer revised parts you need to replace ASAP.
Old Mar 10, 2013 | 09:10 PM
Chris 56 f6
Ford 6.0 Updated Injector Rail Plugs AKA "Dummy Plugs"
My wife came and got me . I had the truck towed to my ford dealer. I m ging to go down there and see if it will start now . If it does start what would that mean, that my stc is bad? And is the hpop hard to get to?
Old Mar 10, 2013 | 09:16 PM
Chris 56 f6
I have a egr delete on it with a sct programmer ! I had it put in when my heads failed !
Old Mar 10, 2013 | 09:21 PM
chetspencer
Yes, but there's much more to it, first if you want to do this yourself, keep reading about bullet proofing your 6.0. if you want to go cheap you can try just changing the Dummy plugs and standpipes to see if that fixes it. My STC fitting was already changed before I bought my truck but I did the oil cooler/ EGR cooler and was already in that far.
Old Mar 10, 2013 | 10:14 PM
Chris 56 f6
I just got back from ford shop truck was there (towed there) it would not start!
I read a little about built proofing my motor but I can not find the full thread .could someone get me there or post a link here? Thanks for the help
Old Mar 10, 2013 | 10:29 PM
BLADE35's Avatar
BLADE35
I saw your thread in that Link in your sig
You could have fixed this I see you like to wrench some there not to bad to deal with normaly
Might as well let Ford fix it this time
But Look into getting a Gauge to read Live data and we can walk you threw the trouble shooting part and Repair next time
I use a ScanGaugeII it 160.00 from autozone
It will show all engine sensors and even some trans sensors
check it out here www.scangauge.com
We could have checked a Few sensors and NArrowed it down
We might of even been able to unplug a Sensor and got it to run
And Welcome to the 6.0L Club
Old Mar 10, 2013 | 10:30 PM
Gental Ben 2's Avatar
Gental Ben 2
My truck died just like yours & it was the FICM.
Pulled out of the gas station after fill up a couple propane tanks & it just died in the middle of an intersection.
Cranked fine, sputtered once, black smoke then '0'.
Old Mar 11, 2013 | 12:01 AM
Chris 56 f6
Thanks for the confidence in my mechanical ability! It s all a allusion !!!
This truck has sucked the life out of me
The resin I'm building a old school rig is I need a back up truck for my problem child 6.0
I have pulled down codes from my stc tuner before . Will that work to tell me what's wrong this time?
Old Mar 11, 2013 | 03:09 AM
Yahiko's Avatar
Yahiko
I vote for FICM (Fuel Injection Control Module)
Have a look in the tech folder at the FICM testing.
All you need is a few smaller torx bits and a volt
meter.Also a helper would be handy.
Sean
Old Mar 11, 2013 | 12:47 PM
gwg42's Avatar
gwg42
My truck died same way when on the road and pulling up to a stop sign. Never would restart. STC fitting needed to be replaced.
