carb base plate
Old Mar 10, 2013 | 04:21 PM
t1956bird's Avatar
t1956bird
carb base plate
Hi all,
I have a 352, in my 1966 F250. with the stock 2V Carb. It has the California emmissions on it.
When taking the engine apart I broke the hose connector on the plate below the carb. The plate is plastic, 1/2 inch thick. A hose runs from this hose connector to the PVC Valve. I cannot find this plate listed anywhere. I searched this forum, not in the shop manual. NAPA couldn't find any reference to it.
Anyone know where I could find one?
Thanks
Rich in Colorado
www.photobucket.com/1966f250
Old Mar 10, 2013 | 04:29 PM
bertha66's Avatar
bertha66
Can you post a picture?
Old Mar 10, 2013 | 09:49 PM
Roger C's Avatar
Roger C
PCV aluminum spacer issue
Originally Posted by t1956bird
Hi all,
Thanks
Rich in Colorado
I got mine at "The Mustang Shop" in Auburn WA. Paid 20 bucks for it, it was off of a 289. Works just fine on my 352... TMS is on the internet. If they have one they'll ship it to you! you won't find it at any parts store! these are not manufactured anymore. I could kick my self at all the stuff I've thrown in the garbage. I think I've tossed atleast 3 of these PCV spacers. Oh if that dosen't work try BEL-KIRK Mustang In Bellevue, WA. They have a website too. More expensive though.
Old Mar 11, 2013 | 02:13 AM
daveengelson's Avatar
daveengelson
If the plate/spacer is in fair to good condition and finding a replacement too expensive or hard to locate. I would find a drill bit same dia. as the opening and drill out the broken piece of plastic tubing then use a high temp, or expoxy glue and replace with another ridgid piece of plastic tubing with outside dia. same as opening in the spacer.
Old Mar 11, 2013 | 02:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 352, in my 1966 F250. with the stock 2V Carb. It has the California emissions on it.
PCV introduced in 1961, was mandatory on all vehicles sold new in CA. By 1966, AFAIK, all states required it.
C5TZ-9A589-C (replaced C5TZ-9A589-A) .. 2V Carburetor Spacer Plate-Made of a composition material that resembles plastic / Obsolete
1965/66 F100/350 352 / 1967 F100/350 352 before serial number B26,001.
No Ford dealer or obsolete parts vendor has any.
Originally Posted by Roger C
I got mine from The Mustang Shop in Auburn WA, it was (aluminum) off a 289.
This is the only 2V carb spacer plate listed in Ford car/truck parts catalogs that meets this criteria.
D2TZ-9A589-A (replaced C3AZ-9A589-D, C9OZ-9A589-A & D0TZ-9A589-C) .. 2V Carburetor Spacer Plate-Aluminum / Obsolete ~ 4 available NOS
1969/74 F100/Bronco/Econoline 302 // 1963/64 Galaxie/Fairlane/Falcon 260/289 / 1965/68 Galaxie/LTD/Falcon/Fairlane/Mustang/Cougar/Bronco 289.
1968/71 Galaxie/LTD/Falcon/Fairlane/Torino/Mustang/Cougar 302.
Old Mar 11, 2013 | 10:24 AM
t1956bird's Avatar
t1956bird
I cannot post pictures, I don't think I have posted enough on this forum.
Here is a link to a picture of it:
http://s1145.beta.photobucket.com/user/t1956bird/media/IM000217_zps49adf7b1.jpg.html?sort=3&o=98#/user/t1956bird/media/IM000217_zps49adf7b1.jpg.html?sort=3&o=98&_suid=13 6301455882302963469240711884
I liked the idea of a Carburetor Spacer Plate-Made of a composition material that resembles plastic to help with keeping the carb cooler. If no one has one to sell, I'll do what Dave has suggested. It's a better idea than I was thinking of drill, taping to insert a brass hose fitting.
Thanks to all,
Rich in Colorado
Old Mar 11, 2013 | 10:48 AM
daveengelson
Hopefully a member will have a replacement; might try posting question in the appropriate engine forum. If it comes down to repairing I would not go with brass, my experience has been it does hold up to engine vibration well. perhaps a section of steel brake line, or something simular with the same i/s dia??
Don't know if the inside dia. of the hose connector is critical; if not, another option may be cutting the broken section at the base and insert ridgid plastic, or steel sleave?
Old Mar 11, 2013 | 11:06 AM
Roger C's Avatar
Roger C
Al dissipates heat pretty well. Ford didn't use them for 50 plus years cause they sucked. Your spacer is aftermarket? Sounds like it might be Bakelite. The older your spacer gets the more brittle it gets also. If you can't afford to buy an Al ford spacer fix it . Ford trucks came with Al spacers and they don't break
Old Mar 11, 2013 | 12:15 PM
camperspecial65's Avatar
camperspecial65
I have several of these spacers...PM for more info...
- cs65
65f100pdx
16
Jun 17, 2020 11:34 AM
roguewave
Apr 2, 2018 12:59 AM
t1956bird
Mar 25, 2013 07:26 AM
59CRL
Jul 17, 2011 02:52 PM
Philo Beddoe
May 23, 2010 01:18 AM
