BIG camper, need dually?
Old Mar 10, 2013 | 12:24 PM
jeffbradbury7's Avatar
jeffbradbury7
91 7.3 idi 4X4 crew cab
my current camper hanges over a foot
the new-er one hanges 3 feet and is on a dually, for now
at what point do I need a dually
Old Mar 10, 2013 | 12:28 PM
Old93junk's Avatar
Old93junk
How much does the camper weigh?...........That will tell you.
Old Mar 10, 2013 | 01:50 PM
Red454sedgwick's Avatar
Red454sedgwick
I dout you need a dually with a camper, single tires can handle alot. aslong as your tries aren't getting hot you'll be fine.
Old Mar 10, 2013 | 02:53 PM
Otahyoni's Avatar
Otahyoni
This.
If you don't already have a rear sway bar, you might consider one. I'm sure you can get everything you need at a salvage yard since some trucks have them factory.
Old Mar 10, 2013 | 03:58 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I had this big old 13ft camper in my stock F250 for 5 years! No sway bars, nothing, just some timbren springs to help take the load.
Old Mar 10, 2013 | 06:16 PM
El Camino Man's Avatar
El Camino Man
You wont need a dually for any slide in camper. They don't weigh THAT much. Just make sure you've got some E rated tires!
Old Mar 10, 2013 | 06:29 PM
raytasch's Avatar
raytasch
Believe Nothing
If the weight of the camper and the truck exceed the weight rating of your tires, especially the rears, you need a couple more wheels. Be sure to include weight of all gear you may stow in the camper, water, batteries, clothes, food, people. Load it up and go weigh it. It is not hard to overload a 3/4 ton truck with a big camper.
Old Mar 10, 2013 | 07:47 PM
IDIDieselJohn
My setup weighed abit over 10,000lbs on load range C tires.
Old Mar 10, 2013 | 09:17 PM
Otahyoni's Avatar
Otahyoni
Just because you can, doesn't mean you should. That's no better than my dad towing a 8k# trailer on a drop ball mount and hitch only rated for 5k# with a Tahoe....
Old Mar 10, 2013 | 09:20 PM
IDIDieselJohn
Gotta do with what'cha got sometimes. Ofcourse a dually be much better with a big camper as it would be ALOT more stable as mine was on single wheels.
And off subject, but I just noticed in your sig, says your 86 is dead and parted out????? The hell happened to it?
Old Mar 11, 2013 | 04:19 PM
RA31925's Avatar
RA31925
On older trucks like yours, dual axles aren't really about adding GVWR but about adding stability. That's not as true on newer trucks, where the GAWR for a DRW axle can be anywhere from 1500 to 3000 lbs more than for a SRW.
It'll help, but you'll probably get better results moving from a 3/4 ton truck to a 1-ton truck, or getting a newer truck, if that's an option.
Old Mar 11, 2013 | 05:13 PM
Otahyoni's Avatar
Otahyoni
Engine gave out and the two i had were also junk... decided it was time to quit dumping money in it.
The previous owner towed a horse trailer with the pump maxed out and no pyro, and liked to blow smoke, so it was on borrowed time when i got it. Finally got to the point that even with ether it wouldn't start unless plugged in overnight...
Old Mar 11, 2013 | 06:32 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Id go with a dually if you plan to leave the camper in. If youre only going to use it for the annual hunting trip and use the truck for other stuff i would stay SRW. If staying SRW use some good quality tires and maybe some air bags. If considering DRW dont forget the option of converting it. Dually stuff can usually be found pretty cheap, the only problem is finding it. Not that much work to swap it over either, fenders might be pricey though.
eberlestock
Dec 23, 2015 08:03 PM
wpinef
Mar 16, 2008 07:30 PM
donfron
Oct 1, 2007 05:03 PM
thebillsmith1
May 27, 2004 12:19 PM
Apr 8, 2001 09:33 PM
