Clutch Replacement?
Old Mar 10, 2013 | 10:55 AM
crazy4wdracer's Avatar
crazy4wdracer
Clutch Replacement?
Well its finally getting warmed up here and my truck needs a clutch. I already got a clutch from Kenny. I'm just wondering how hard of a job this is to do myself...I have a motorcycle jack for the tranny and plenty of tools.
Truck is 2wd by the way
Old Mar 10, 2013 | 06:05 PM
jetdoc's Avatar
jetdoc
I did mine in my driveway. I rented a trans jack because I pulled the transfer case and transmission out as one unit. It was heavy. Pretty straightforward job. Make sure you clean the dowel pins before you reassemble. Need to pull it again this year to get the trans overhauled. Third gear synchros are history.
Old Mar 10, 2013 | 06:32 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I have done this as well, I have a shop with a cement floor much easier,the process is pretty straight forward, one tip get the truck as high as possible and still be safe, these tranys are huge and heavy.
Old Mar 10, 2013 | 09:16 PM
tennesseecoalroller0's Avatar
Its not a bad job at all, just rent you a good quality trans jack rated for big stuff, pull the trans and t case all at once, make sure u get the truck high least the front end, dont put too much wheel bearing grease on the shafts, torque everything u can get to to specs, get ur flywheel resurfaced and make damn sure u got alot of extentions and universals.
MattMac
28
Feb 2, 2017 03:38 PM
Memphis_Sean
50
Nov 15, 2014 10:16 AM
superduty4x4
Feb 10, 2012 11:44 PM
gbeach
May 19, 2007 06:10 AM
StevenRanger
1983 - 2012 Ranger & B-Series
18
Jun 3, 2004 12:32 AM
