Is it possible that the clutch disk is in backwards? I'm pretty sure I put it in with the "this side to flywheel" side facing the flywheel like it should...
Ok so I crawled down under the truck while my dad was inside depressing the pedal... The fork was only moving about a half inch... Now to figure out why
Open the hood and look at the master cylinder as he steps on the pedal.
Check the little 4 fingered clip that holds the master cylinder pushrod on. (it's above the gas pedal.
I did away with the fragile plastic and put a brass bushing in its place.
