Leaf spring bushings.
Old Mar 9, 2013 | 08:13 PM
sand_fiend's Avatar
sand_fiend
I have done a little browsing but didn't really find an answer.
I need to replace my stock front leaf spring and frame bushings
Is anyone offering a complete kit or did you just go to your local auto part store
Old Mar 9, 2013 | 10:04 PM
Diablo540's Avatar
Diablo540
I would ask local truck spring shop for the bushing kit they usually carry anything needed for springs
Old Mar 10, 2013 | 11:38 AM
crop harvester's Avatar
crop harvester
you might look at Energy suspension parts or similar brands.very easy to install.
Old Mar 10, 2013 | 05:41 PM
Punisher29073's Avatar
Punisher29073
I did the Energy kit all the way around and replaced the leaf isolaters as well. Thay are only available from the dealer. So much better, no more rattling. It was quite a job. It will be much easier with an extra set of hands, but well worth the investment.
Ryan
PS. I did have to trim the front ones a little but it wasn't hard.
Old Mar 12, 2013 | 10:03 AM
ztodd377's Avatar
ztodd377
Did the front bushings not fit as is?
Old Mar 12, 2013 | 10:43 AM
SteveH-CO's Avatar
SteveH-CO
Sometimes I have found urethane bushings to be very tight, due to them being overly long inside the spring. A few seconds on a bench grinder shortening the inside end can take care of this.
Old Mar 12, 2013 | 02:27 PM
Punisher29073
The part I had to trim was on the outside lip of the bushing. The part that goes into the curl on the leaf fit fine but on the front of both front bushings I had to cut a little off of the lip around the bushing to clear a spot that wasnt machined on the mount. A round lip wouldnt fit, it had to be flattened on the top. It is hard for me to explain, but it wasnt difficult at all.
Ryan
waylen89
Aug 8, 2016 03:45 PM
newguy399
Aug 6, 2013 03:13 PM
airharley
Oct 3, 2007 09:00 AM
gatorpsd
Mar 30, 2006 09:21 PM
