bushing help
Old Aug 5, 2013 | 02:07 PM
newguy399's Avatar
newguy399
bushing help
Hey guys just received my bushing kit for front spring, and one of the bushings slide right thru the eye.
any suggestions on what to do
Old Aug 5, 2013 | 04:59 PM
raytasch's Avatar
raytasch
Believe Nothing
If you have a bushing in the frame, it may be smaller than those in the spring. Examine the parts and where they go closely.
Old Aug 5, 2013 | 05:39 PM
newguy399's Avatar
newguy399
No its a spring leaf bushing for the front from midfittys
Old Aug 5, 2013 | 11:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Was the old bushing hammered to pieces? About all you can do is take the whole sproing to a spring shop and see if they can tighten the eye, but if it's an old old spring there may be a risk there... They can make a new top leaf, might be a better idea. But the cost of the top leaf may be 50% of the cost of "store bought" whole new spring. And if you replace one side.... See how costs spiral?!
Old Aug 6, 2013 | 05:00 AM
AXracer's Avatar
AXracer
did you try swapping the bushing that fits for the one that is too small and/or measure both bushings and spring eyes with a calipers to see if it is the bushing or the spring eye? Could be simply that the wrong bushing ended up in in the wrong labeled bag, or an oddball spring ended up on your truck.
Old Aug 6, 2013 | 09:16 AM
newguy399's Avatar
newguy399
Yeah I did all that and the bushings are all the same. Talked to a spring shop and they said to tack weld it but thanks for the help guys
Old Aug 6, 2013 | 09:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Welding on a spring eye?!?!
I don't see what they think that would accomplish. The bushing isn't going anywhere, it's just a sloppy fit. How sloppy is it? Enough to rattle, or just not tight? Usually they are pretty hard to press in.
Old Aug 6, 2013 | 09:29 AM
raytasch's Avatar
raytasch
Believe Nothing
If the spring eye is actually larger than standard look closely for hairline cracks. Might just cut a tin can into strips and press them in with the bushing if you really want to tighten it up. Like Ross said, it is not going anywhere. Just how much slop is there in the eye? Remember to grease well.
Old Aug 6, 2013 | 10:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
21C-5348-A .. Front Spring-Front & Rear Bushing-1.72" long
1948/52 F1/F2 & 1953/56 F100/250.
59Y-5781-A .. Rear Spring-Front & Rear Bushing-2 7/32" long.
1948/52 F2/F3 & 1953/56 F250/350.
Left: F250/350 REAR Spring / Right (upper): F1/F2 & F100/250 FRONT Spring.
Old Aug 6, 2013 | 10:17 AM
53OlderThanMe's Avatar
53OlderThanMe
I had a similar issue, old bushings tight new ones loose. I went ahead and used them anyway, the ride was awful. New springs rides likes a Caddy (not quite).
Old Aug 6, 2013 | 11:40 AM
newguy399's Avatar
newguy399
There is enough play that I can push the bushing in and out with no resistance but not so much side to side of that makes sense. The other three went in fine with a press.
Old Aug 6, 2013 | 12:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The problem with a loose fit in the spring is that the bushing may spin in the spring instead of spinning on the pin. Likely why it's loose, not enough grease at some point. If you can shim it tight, great, if not, maybe live with it until you need springs? It doesn't sound real loose.
Old Aug 6, 2013 | 03:13 PM
newguy399's Avatar
newguy399
Ok will try it. The truck is still in prices so I have a long way to go before its drivable. But thanks for all your help. This is a great forum
Jager
Nov 15, 2010 04:54 PM
Allenson
Aug 29, 2007 12:35 AM
skittlejr
Feb 27, 2007 12:59 PM
gatorpsd
Mar 30, 2006 09:21 PM
mayerst1
Mar 10, 2006 10:26 AM
