6.0 reliability
Old Mar 8, 2013 | 10:54 PM
dauntejoel's Avatar
dauntejoel
6.0 reliability
Hey guys I've owned my 05 6.0 for almost a year. I plan on keeping it stock for awhile. I was wondering how to make it a good reliable stock 6.0. I've put a new stc fitting oil cooler blue spring mod new batteries new cac boots an egr delete and I've cleaned the turbo I use synthetic oil and ford filters. Do I need arp head studs or will it be OK if I leave it stock. But anyway wat other things would make it more reliable
Old Mar 8, 2013 | 11:21 PM
Piolet's Avatar
Piolet
Get yourself the necessary gauges to monitor what the engine is doing. Based on the list of work you have posted I'd say you already know that.
This engine can be reliable on its own, but the gauges will stop a minor battery problem from becoming FICM or injector blues for example.
When the time comes for a new alternator, upgrade from the stock one.
These engines can survive fine with stock bolts if you don't tune it. If you are ever into the oil cooler again, then maybe consider a swap to studs at that time.
Old Mar 9, 2013 | 06:48 AM
bismic's Avatar
bismic
Have you upgraded the dummy plugs and standpipes? I also think that the updated turbo drain line is worth it, but some disagree.
Old Mar 9, 2013 | 10:20 AM
dauntejoel's Avatar
dauntejoel
No I haven't done the standpipes and dummy plugs wat do those do. I forgot to add I put the 6.4 banjo bolts on and I have a scan gauge.
Old Mar 9, 2013 | 10:23 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
coolant filter?
Drive it.
Old Mar 9, 2013 | 10:37 AM
Kayteg1's Avatar
Kayteg1
I am still trying to figure out new to me 2007 model and I found the information about those engines pretty much scattered all over and confusing.
Do we have a topic summarizing new owner advices, or is it necesary to do each point separately?
My truck come with 144k on it, so it can't be bad making it so far? Than I found advice about EGR delete and fuel regulator spring upgrade.
Those sound like things worth doing, but could not find any info about time involved. Looks to me like EGR is having several options to delete and some of them might take 2 days of labor?
Now on my engine down under I have something that looks like coolant filter to me. Would that be factory option for my MY?
Old Mar 9, 2013 | 10:40 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yes, we have a couple of concise "do this" threads:
Ford Truck Enthusiasts Forums - View Single Post - Just bought 06 F350 FX4 6.0!!
https://www.ford-trucks.com/forums/9...used-6-0l.html
Ignore the "before you buy part" and change it to "now that you've figured out what you bought", and follow the checklists.
Detailed walkthrough of the blue-spring upgrade, also doubles as a pictorial walkthrough of how to change a thermostat:
https://www.ford-trucks.com/forums/1...ue-spring.html
EGR cooler/Oil cooler R&R with STC replacement. doubles as pictorial guide to EGR delete, turbo removal, and secondary fuel filter/oil filter housing work:
https://www.ford-trucks.com/forums/1...many-pics.html
Coolant filter:
https://www.ford-trucks.com/forums/7...nt-filter.html
This is a home made one, the kit's won't be drastically different. A coolant filter was never an option on a Ford 6.0L.
And finally, this guy:
6.0 Liter Ford Powerstroke EGR & Oil Cooler Replacement - YouTube
He has video series that cover everything from removing the turbo all the way to a complete head gasket job. If you want to replace standpipes/dummy plugs, watch his injector replacement video. If you want to do an STC fitting, he has a video, if you want to do an EGR delete, watch his oil and EGR cooler replacement video and know you won't reinstall the cooler and you'll change the passenger's side up-pipe out.
Pretty much all of these come from the Tech Folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Mar 9, 2013 | 11:08 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
If what you are looking at is on the passenger side frame rail, that's the transmission fluid bypass filter. No factory option coolant filter was offered for our trucks.
Old Mar 9, 2013 | 05:22 PM
Kayteg1's Avatar
Kayteg1
Nice list you have made texastech and it sure is lot to read, but I did not buy the truck for $7000 to spend $10,000 on mid-age improvements.
At this point I am not sure any of them have been made on truck, but coming from utility company, most likely the engine is original.
I am not planning to chip it as the 325 ponnies is already improvement from 250 I had in 7.3, so not seeing dollar or hours amount behind the jobs, it is hard to figure out priorities.
Old Mar 9, 2013 | 05:32 PM
bismic's Avatar
bismic
You can do all the necessary mods on a 2007 for $2k-$3k, not $10k. You almost certainly do not need head studs unless it was not maintained or it was abused. When people are getting 300k miles out of the 6.0L, then what is considered "mid-age"? Even 100k miles is not yet mid-age in my mind. Buying a used 6.0L can still be a good financial decision - even w/ spending the $$'s on reliability upgrades.
If the oil cooler is not plugged, the highest cost upgrade is a BPD EGR cooler. Some say delete it, but IMO, a PROPER delete would also include a tuner to account for the change in combustion parameters due to no longer having the exhaust gas recirculating back. The next highest cost is the STC fitting upgrade. Doing it all at once is cheaper.
Old Mar 9, 2013 | 05:50 PM
Kayteg1's Avatar
Kayteg1
Bought the truck with 144k and not likely I will put another 144k with my usage.
So coming down to the point, would monitoring the engine be sufficient to guarantee long engine life? I am using $20 ELM with my computer to see what the engine is doing, but than see others spending $2-400 on other monitoring system.
Did someone made a program that would ring a bell on the computer when engine goes in wrong direction? I read that my 2007 model will light CEL when coolers temperatures will go too much different. Is that sufficient protection?
The PO did not make those upgrades and I doubt company drivers babied the truck.
It shows average 25 miles per engine hr, so it was idling a lot, what is understable as it had small crane mounted on it.
What are my chances to make another 144k doing nothing?
Old Mar 9, 2013 | 06:18 PM
Piolet's Avatar
Piolet
Bought the truck with 144k .... What are my chances to make another 144k doing nothing?
That would be 290,000 miles. Doing nothing to get there I would say the chances are slim.
Transmission may last, may not. I think 230K-250k range before an overhaul can be expected. Also expect an oil cooler, alternator, maybe HPOP, some injectors, turbo cleaning.
You may not see all these, but I think you will see 1 or 2 of them.
... would monitoring the engine be sufficient to guarantee long engine life?
It doesn't guarantee, rather it helps reduce repair costs ... as long as you pay attention to what the gauges tell you.
When FICM volts go bad, acting on the info provided could save you injector $$$.
When oil and coolant temps get far apart, acting on the info can save you head gasket $$$.
When fuel pressure gets low, acting on the info can save you injector $$$.
Old Mar 9, 2013 | 08:32 PM
Kayteg1's Avatar
Kayteg1
I meant doing nothing from the engine modifications. I still plan to do factory recommended maintenance
I am still playing with my ELM.
It gives me a message that I have 3 car computers like ECU$7 with E9, E7 and ED on the end. I connected into E7 and it gave me several readouts like coolant temperature and control module voltage, but I don't see oil temperature.
Shall I connect to other modules to find the data?
Old Mar 10, 2013 | 03:46 PM
smacDiesel's Avatar
smacDiesel
I just posted a similar topic, lol! Great info everybody!
Old Mar 10, 2013 | 07:36 PM
bismic's Avatar
bismic
FYI - You can get the scangaugeII monitoring system for $140.
shore
Feb 19, 2017 05:16 PM
eaglewwit
Jun 10, 2014 03:37 PM
kornfanjoe
Apr 25, 2012 09:08 PM
Totally Tuna
Oct 11, 2011 05:11 AM
tuneport21
Sep 1, 2011 03:30 PM
