Weigh in time. What's your guess?
Exactly. With a flatbed I'm "supposed to" pull into weigh stations. So if I run into some a-hole for a highway patrol. $$$$. I'll be helping california get better roads.
I guess I was way off! I could have sworn that my truck was just under 7k empty. I'll have to roll it across the scales again I guess and see.
I wouldn't worry about the weight hurting the truck. By adding the 4x4 you have a heavier duty axle under the front there as well. These rear ends can take a lot too, so I wouldn't worry about that. Johnny Law, though..... that's another issue. I don't know how you get around that issue. We don't have to worry too much about that around here.
BTW, it looks like Todd was the closest.
Sounds kinda evil… I like it!! Sooo what's the GAWR of a Dana 60. I looked a little bit but didn't find any set in stone number.
My front gawr is 4600 lbs on the F350.
For information sake my truck with no fuel minus spare, tailgate, and tools weighed 6880. In cali our registration is calculated by weight, so I wanted to get it under 7000 lbs .
Splatts, I know of a lot of rigs running around up here over weight. Normally the CHP isnt too bad about being the weight police, but you're a lot farther south than I am.
Where are you planning on moving to?
Waiting to hear back from a couple jobs in the homeland of Washington. I haven't been caught yet by passing the scales but the law says something to the effects of. Pickups with an altered bed are required to stop at the scales. I might just be paranoid but I don't want any hang ups when it comes time ya know what I mean.
You can try to do what i did, In PA you can go to a fast tag place and get a form to adjust your gvwr, My 95 f-350 dump truck was 11k which i didnt like since cops around here weigh alot of trucks and at 11k i was always over weight. I went to https://www.fleet.ford.com/maintenan...ls/default.asp
I put my vin in and said i was in a range of 10,000 to 14,000 pounds. So on the form i wrote to adjust it to 14k. I had to print that paper out and take the form to my inspection guy and he signed off on it. Turned it into dmv and got truck approved to haul 14k. So i scrapped off the vin tag on the door and keep a copy of that vin sheet and my title in the glove box saying that im legal for 14k. I tried your vin but says your in 6-10,000 range. sounds like some photo shop work to change that to a higher number ha.
less
03-15-2010 06:35 AM
