Odometer Not Reacting
Old Jun 1, 2003 | 08:12 PM
Taylorisaboy's Avatar
Taylorisaboy
Post Odometer Not Reacting
Whats going on with my Truck. Coming back from Vac. the Odometer started to drop off and on from around 70mph to 40mph. It would not start to read until I got up to about 35mph.
Also the Overdrive light on the shifter would blink from a dead stop until it went through the gears. To start off these misterious things the ABS light came on. Can anyone help?
Old Jun 2, 2003 | 06:54 AM
powerstroker250's Avatar
powerstroker250
Possibly the speed sensor on top of the rear differential is going out or there is a loose connection.
Old Jun 2, 2003 | 01:07 PM
CO_BoatTractor's Avatar
CO_BoatTractor
I had a similar problem on my '99 F350.
There is a 3 wire twisted harness that routes through the shifter tube to the OD on/off switch. The wires were routed such that they rubbed on the shifter boot bracket. 3 screws hold the steering column cover on. Remove this, and the wiring is easily visible. I had to unplug the wiring, remove the shift lever, and repair them. It took about 20 minutes, and all was well again.
Old Jun 3, 2003 | 09:44 PM
HP junkie's Avatar
HP junkie
I had same problem on my '99 F-250. It would be your speed sensor located on top of rear diff. I asked same ? about a month ago and got a quick and accurate response. The part cost $15-18 and takes about 15 min to install. Just don't get any dirt in the rearend (not good). best of luck and enjoy working on your truck!
Old Jun 10, 2003 | 10:14 AM
Cheetah Daddy's Avatar
Cheetah Daddy
Have similar problem. Just installed the Tymar Air Intake System this past weekend. Shortly thereafter I started having the follwing problems:
1) ABS Light stays on.
2) Service Eng Soon Light stays on
3) Next day, the Overdrive Off Light flickers on & off constantly.
4) Odometer needle flutters ,,, and drops to zero when i let off the gas (even if costing 20+ mph.
Could I have bumped something at install time?
Could the on board computer be going crazy since I disconnected the drivers side battery only ........ should i diconnect both batteries and see if the computer resets?
Any help is appreciated.
Old Jun 10, 2003 | 04:03 PM
CO_BoatTractor
I dont think disconnecting one battery versus both will make any difference, as that they are in parallel. What year is it?
Old Jun 10, 2003 | 04:47 PM
Cheetah Daddy
Early 99' F350 7.3 Crew Cab 4x4.
Old Jun 11, 2003 | 07:30 PM
MrFeexit's Avatar
MrFeexit
Speedometers are over rated anyway...
Old Jun 22, 2003 | 06:17 PM
Taylorisaboy
Hello Guys,
Thanks alot for Info. It was the speed sesnor located on top of the rear end.
Thanks.
Old Jun 23, 2003 | 11:55 AM
Cheetah Daddy
Apparently this speed sensor causes havoc to the computer. See my problem logged under " Warning Lights Going Crazy After Tymar Install"!
My problem had nothing to do with the Tymar Air Intake install ... just a coincidence that the speed sensor went out at the same time.
Had ABS, Service Engine Soon, and Overdirive lights on which left me chasing several ghosts all caused by this one sensor.
BEWARE to all!
elmoycas
Aug 1, 2014 09:46 PM
dfarland
Sep 23, 2010 03:06 PM
Pwy_FireCapt
May 7, 2010 06:10 PM
Jporterfield
Jul 29, 2003 06:21 AM
