Sponsored by: Real Truck
Noticed something "odd" when going into 4 wheel drive...
Old Mar 6, 2013 | 08:53 PM
rhillman75's Avatar
rhillman75
I bought a F250 6.0 Crew Cab 4WD last April. I never really needed to use the 4Wd until last evening when the snow storm hit. I was doing about 20 MPH when the rear went all over the place so I waited until I got straightened back up, continued to go about 20 MPH, and turn the dial to 4WD high. It did make a slight "clunk." Figured it was normal so I continued on about 5 miles doing about 30-35 MPH to my home. I pulled up into the driveway, and while still in drive but not moving, I turned the dial back to 2WD and "physically" (rather loud "clunk" that you could feel in the cab) felt the underneath shift out, or so I "thought." I went to leave the next morning in what I "thought" was in 2WD and noticed a slight noise from the front end. It was enough to notice it over the diesel idle. I came to a stop sign and when I came to a complete stop it sounded as if the front hub then finally went back to normal. The warranty is out in about 2,000 miles. Should I start investigating this or is it normal. My rims do have the manual locking hubs, if this gives anymore input, however I have never touched them.
Old Mar 7, 2013 | 05:59 AM
hanklin's Avatar
hanklin
bump ^^^^^^^
Old Mar 7, 2013 | 06:09 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your truck has manual hubs? Are you sure they are not the automatic hubs? They look the same at a casual glance, but they say AUTO instead of FREE in one of the two positions.
Old Mar 7, 2013 | 06:11 AM
hanklin's Avatar
hanklin
When did Ford stop putting in levers? Thanks Redford
Old Mar 7, 2013 | 07:30 AM
mikeismadness's Avatar
mikeismadness
I believe you have to have an XL model to get the lever
Old Mar 7, 2013 | 08:25 AM
Fishin76's Avatar
Fishin76
I have a XLT with a lever, It is a commercial/fleet truck, but still is a XLT. I don't even have 4x4 stickers on the truck, and it never came with them new.
Old Mar 8, 2013 | 06:13 AM
hanklin's Avatar
hanklin
Pretty sure its year specific as newer ones have esof. I myself have a lever and its an xlt
Old Mar 10, 2013 | 03:50 PM
FarmingF250's Avatar
FarmingF250
Lever is standard equipment on all XL Super Duties, and depending on the year, standard on higher trims. ESOF was normally optional, but was standard on higher trims depending on the year.
I have an XLT with manual 4x4.
Old Mar 10, 2013 | 06:11 PM
fordman19762003's Avatar
fordman19762003
From '11+ the lever operated t-case is standard on XLT and lower. The lariat and up only come with ESOF. I'm not sure about the pre '11 trucks but I'm pretty sure the manual set up would've still been standard on the XLT and lower.
Old Mar 10, 2013 | 06:15 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
sounds like normal sound to me, some make more noise than others but my 95 and my 01 as well as my single cab 99 all make a loud sound if ive been using it hard, i think it has some thing to do with warm vs cold fluid on the T Case
Old Mar 10, 2013 | 06:23 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
To the original post......
Sounds like you just have a case of a laggy 4x4 system. What probably happened was you disengaged the transfer case, that is the thud you heard, which is normal. However, either because you shut off the truck before vacuum built up, or because you have some sticky auto lock hubs, the hubs did NOT disengage. This is not a big problem, but will cause the front axle shafts and drive shaft to spin. No damage is done to the transfer case in this scenario.
If this is indeed what has happened a little maintenance is all your truck needs.
shaferz
Jan 28, 2012 10:45 PM
speedfreak87
1983 - 2012 Ranger & B-Series
15
Nov 6, 2011 06:54 AM
dicaro
Dec 5, 2008 10:46 AM
B1GKAHUNA
Jul 27, 2008 03:42 PM
Green Streak
Apr 14, 2006 07:59 PM
