Silly Question
Old Mar 6, 2013 | 08:45 PM
jrockdiddy's Avatar
jrockdiddy
Silly Question
This might be dumb, but I'm a beginner Why exactly do some of you fellow FTE members use the Toyota p/s box? It's so expensive on the midfifty website, but my guess is that it has to do with IFS or something? Maybe a straight front axle?
Go easy on me!
Old Mar 6, 2013 | 08:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Very few boxes have a horizontal pitman arm shaft, like the stockers and the Toy box. Almost all have a vertical output shaft.
Old Mar 6, 2013 | 09:05 PM
CharlieLed's Avatar
CharlieLed
Like Ross said...they fit like a glove and they give your stock "armstrong" steering a little power boost. As for the cost...when you drive one of these trucks with a power assisted steering setup you will understand why they are worth the money. If you are going to an IFS then the Toyota box is not for you.
Old Mar 6, 2013 | 09:12 PM
The Horvaths's Avatar
The Horvaths
I just want to find something to fit theF500/600 class. Hmmm..
Old Mar 6, 2013 | 09:14 PM
jrockdiddy's Avatar
jrockdiddy
Ah... I see. And I have mustang II so no box for me
Old Mar 6, 2013 | 10:02 PM
CharlieLed's Avatar
CharlieLed
With the MII you have the option for a MANUAL rack & pinion or a POWER r&p.
Old Mar 6, 2013 | 10:42 PM
jrockdiddy's Avatar
jrockdiddy
I already have a new power rack, but I was just curious about this Toyota steering box everyone was talking about. Now I know, thx dude's
Old Mar 6, 2013 | 11:33 PM
AXracer's Avatar
AXracer
The Toyota box is a modern design recirculating ball power steering box that virtually bolts in place of the OEM box like it was designed to go there and is a perfect match for the beam axle. The price of the rebuilt Toy boxes isn't bad when you compare it to the price of a rebuilt stock box that still uses a design originally used in the 30's. But the Toy box is so well built that using a salvaged box (typically available for 25.-125.00) is a safe bet. Rebuilding the front beam and installing the Toyota box is about 25 - 33% the cost of the MII and doesn't require any special skills or major equipment to install.
joelburn
Mar 7, 2012 05:11 PM
james gang 1001
Feb 25, 2010 10:47 AM
fastman35
Jan 17, 2007 09:17 PM
1970Custom
Aug 29, 2005 05:43 PM
FatMike86
Aug 18, 2002 11:37 PM
