which gear ratio
Old Mar 7, 2013 | 03:59 PM
garthneddy's Avatar
garthneddy
Originally Posted by GBuckert
You're getting more torque to the ground, but you'll be running at a higher rpm for the same speed as before. If you go so low that overdrive works at 30 mph, then it would run at a lower rpm. Higher rpm means more fuel usage.
It won't be as noticeable as it would be on the highway, but it'll be there unless you spend all your time accelerating and braking with no constant speeds.
After longtube headers my pickup now drives much better, can actually merge into traffic. I would go with 4.10s if I daily drove my pickup.
City driving IS mostly accelerating and braking. Plus you will be able to get into higher gears earlier, thus reducing the engine RPM and fuel consumption
ech0sh4y
Jan 14, 2009 11:13 PM
sonchaser91
Jun 9, 2007 12:46 PM
94fordlover
13
Jul 17, 2006 05:10 PM
Tepot
Jan 1, 2005 06:03 PM
JasonBrod
1978 - 1996 Big Bronco
Oct 17, 2003 08:00 AM
