Sponsored by: Real Truck
4x4 Hub Puller
Old Mar 7, 2013 | 05:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by grec-o-face
Here in the Boston area (points south) I've run into this more than once. Usually it takes some time and light persuasion with my favorite dead-blow hammer.
Just working it left > right > left > up > down > and so on.... Also might try a strap wrench for some leverage, but I like the Channel Lock idea better!
Then, once it's finally outta there... clean the surfaces and treat with your favorite lube/anti-seize. Remember, a little goes a long way.
Swearing during this process also helps.
Old Mar 7, 2013 | 05:24 PM
99f350sd's Avatar
99f350sd
I'm the one who had to destroy my stock hub on the drivers side to get it off..It was corroded so no way was it coming off. I had to crack it in half and use a slide hammer after i drilled holes in it...Like 3-4 hours later..
Dick
JamesB128's Avatar
JamesB128
Yes Red I would have to agree. Sometimes a few choice words at an inanimate object does indeed help.
Old Mar 22, 2013 | 12:46 PM
EJSF350's Avatar
EJSF350
Update
Dick,
Sounds like your hub was as stuck as mine, so I am sure you know what I am up against.
I spent a half day trying to remove my other hub with no success. I managed to seriously scar it up with the pliers, but it wouldn't budge. This time I also tried rapping it with a hammer that has a solid, pure lead head. While I still didn't get the hub to break loose, at least I have not yet damaged it.
So, rather than give up and take the air hammer to it, I broke down and bought that special hub puller (QT1124). If it gets this hub out in reusable condition, it will have paid for itself in one usage. If not, I reckon I can survive the loss (education is never free).
If there is any interest, I can post my results in a week or two...
Mac J
Nov 23, 2016 09:40 AM
cntryboy8541
Apr 18, 2011 01:27 AM
automike25
Jan 27, 2007 07:23 PM
Will_01_GT
1978 - 1996 Big Bronco
Mar 2, 2006 08:11 PM
RawPower
Jun 1, 2005 12:22 PM
