GT40 Heads and Headers
Old Mar 5, 2013 | 05:15 PM
Intimnasc's Avatar
Intimnasc
I have my motor and am almost ready to take it to the machine shop. I will be spending the rest of this week looking for a set of GT40 heads. Both questions referr to a 94 F150 that currently has a 300 6 and am building a 351 Windosr from a 95-96 F-250.
My first question involves the heads. I have read they came on 96 Ford Explorers and 96 Mercury Mountaineers. I am assuming this was on all the 302's? Was this the only head used in that year model? What and where is the casting number to look for?
I have been looking at long tube headers on line and see some with the EGR port. Will I pass emissions for the next few years without hooking up the Air Pump? If I weld ports into the headers for the Air pump, is it OK to put them in the rear most tube or does it need to be down by the collectors?
Old Mar 5, 2013 | 05:30 PM
el_mudo_73's Avatar
el_mudo_73
Look for the sign of gtp/ gt40 I'm not sure all exploders or mountaineers had the heads you want but if you see gtp or gt 40 then dats the way to go
Old Mar 5, 2013 | 05:33 PM
el_mudo_73's Avatar
el_mudo_73
If you get c.a.r.b headers with air pump slots you shouldn't have a problem but once you start upgrading into performance then you should always know their a sacrifice to be made
Old Mar 5, 2013 | 06:52 PM
nflfreak43's Avatar
nflfreak43
96 explorers/mountaineers 5.0's had GT40 heads.. 97 and after 5.0's had GT40ps..
The regular 40's have 3 bars cast on the front of the wads.. The P's are 4 bar..
The P's require special headers cause a different plug angle.. But are better than standard 40's..
Gt40's also came on 93 mustang cobra's and 93-95 lightnings..
Old Mar 5, 2013 | 11:28 PM
Intimnasc's Avatar
Intimnasc
On the 302's are the AIR ports in the heads? Cause on my 3/4 ton 351 they are in the exhaust manifolds.
Old Mar 6, 2013 | 12:52 AM
el_mudo_73's Avatar
el_mudo_73
I've use regular ceramic Ford racing headers on gtp heads and then on gt 40s and never had a problem Jus one spark plug curb on the header flange had to be modified so the sparkplug socket would fit.
The only headers that I wouldn't use are crappy m.a.c. same length headers no good Jus looks but crap
Old Mar 6, 2013 | 09:26 AM
Conanski's Avatar
Conanski
The heads on all full size truck engines have ports in the heads, it's anybodys guess why Ford felt the need to design a different system for the HD truck. In general GT40 heads don't have these air ports but there were a some that did.
Old Mar 8, 2013 | 11:43 PM
Intimnasc's Avatar
Intimnasc
I found some heads at the local JY. They turned out to be GT40P heads instead of the GT40's I was looking for. Everything I have read says headers are a pain on these heads for spark plug clearance and burning up wires. I am looking for Long Tube Ceramic coated headers with an EGR port and an O2 port. If I ABSOLUTELT HAVE TO I will weld in ports but would rather start with the right stuff.
Old Mar 14, 2013 | 11:40 PM
Intimnasc's Avatar
Intimnasc
OK so I found some long tube headers with the EGR port and the O2 sensor ports already in. My next question is do I get the ceramic coated or not? It is my understanding that the ceramic coating aids in heat distribution. Basically acting as a heat shield as opposed to putting heat shielding material around them.
Old Mar 15, 2013 | 09:28 AM
Conanski's Avatar
Conanski
Yes ceramic coat them but mock them up on the motor and clearance everything that needs to be before sending them out to be coated.
Old Mar 17, 2013 | 01:32 AM
Intimnasc's Avatar
Intimnasc
So son't buy them already coated buy the plain steel headers and fit them. I didn't even know you could get them coated locally. I'll have to look. I was talking coated from the manufacturer.
1981 convert
Mar 9, 2016 11:48 AM
chubrock108
Jun 6, 2012 08:40 AM
USMC0351fordtruckin
Mar 14, 2011 12:12 AM
big_ford_rednek
Nov 4, 2009 07:15 AM
braves10
Nov 21, 2002 04:58 PM
