240 / 300 Head
Old Jun 1, 2003 | 05:50 PM
lrac's Avatar
lrac
240 / 300 Head
Other than increasing the compression ratio by using the 240 cid head on my 300, are there other advantages/dis-advantages to take into consideration. Am I right in figuring that if the 240 had a compression ration of 9.2 then that head on a 300 would give a ratio of 11.5?
Thanks for any advise,
Old Jun 1, 2003 | 06:49 PM
chuckman's Avatar
chuckman
240 / 300 Head
theres a good explain of what kind of comp you can expect over at FSP, heres a linky:
http://fordsix.com/forum/viewtopic.php?t=5343
hope that helps
Old Jun 23, 2008 | 03:50 PM
Iman901's Avatar
Iman901
Im not sure it would be that high, 300s came with really low compression- like in the 7s- for emissions reasons
Old Jun 23, 2008 | 05:29 PM
Harte3's Avatar
Harte3
I think the lower cr's came in the HD engines that were used in heavy trucks like 2 ton type farm trucks.
Old Jun 26, 2008 | 11:52 PM
Iman901's Avatar
Iman901
sorry about that, I was looking at a chart of CPs in a manual, the low ones were actually from a 360V8.
I just read in another post that the 300EFI head had the same size chamber as the 240 plus its a more efficient design.
gear_grinder
38
Dec 24, 2020 02:12 PM
CaptJak
17
Jan 30, 2015 06:16 PM
bigfootsurfin
19
Jan 2, 2015 01:48 PM
gdavis2265
Mar 7, 2003 08:07 AM
82F100SWB
Jun 9, 2002 11:01 PM
