voltage regulator connection question
Old Mar 5, 2013 | 09:03 AM
jxnslotcar's Avatar
jxnslotcar
Question voltage regulator connection question
I have a 62 Unibody with a 462 Lincoln engine installed. My problem is the wires going into voltage regulator. What does the I and A stand for on the regulator? I have these 2 wires going into the cab going nowhere. I just installed 6 new guages into a custom panel I made. These 2 wires need to go somewhere and it has been so long since I worked on an external regulator that I have forgotten what these mean. I am getting this ready to go to the Detroit Autorama this weekend and doing the last detail stuff on the truck. This is not an "upstairs" truck. It is a "driver" and going in the basement.
Old Mar 5, 2013 | 02:10 PM
james64's Avatar
james64
this should help
Old Apr 23, 2013 | 04:23 PM
jxnslotcar's Avatar
jxnslotcar
I just wanted to thank you for this diagram. Big help Thank you
Old Apr 23, 2013 | 05:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
462: 1966/67, some 1968 Lincoln's, all came with alternators.
Alternators first installed on 1963 Thunderbirds, everything else got them in 1965.
Old Apr 23, 2013 | 07:24 PM
old broke prospector's Avatar
Correct me if I am wrong but on the diagram...
It is important to note the I going to the Indicator light then goes to the Ignition such that the wire is energized only when the key is on. I mention this for those that are wiring the trucks without using the existing color coded wiring harness.
75Three90
27
Nov 16, 2023 09:06 PM
jazzydog
Aug 19, 2012 09:01 AM
low and fast
Jun 26, 2009 10:57 AM
79 250 lariat 4x4
Electrical Systems/Wiring
Oct 31, 2003 09:05 PM
