I got one of those clever little code readers and pulled the codes, as advised by GLR & CTUBUTIS.
And as everyone knows, it's not so much what the test results are, it's how to interpret those results.
The error codes I got were:
KOEO: 63
C: 63
KOER: 23
All pointing to Throttle Position Sensor. I have one on order, so I assume the fix is a simple replacement of the TPS. Another poster said he carried one around as a spare, so I presume this isn't a difficult job.
Any other insights on these error codes would be welcome.
I would disconnect the battery before replacing it, that will let the computer re-learn the idle speed settings. I've seen weird things happen when I went and changed that part behind the computer's back, without letting it know it's been changed....
Uh...yea I've had my share of the same problem a log while back, after replacing I disconnected the battery for an hour and then had to drive it "normally" for 10 miles for it to relearn itself..oh and I also changed the fuel filter (round cardboard type in a canister around the drivers side in the frame rail..be sure to use a lube on the gasket as they have a habit of deforming if its not in there right or it's too tight)...
