Code P0470
Old Mar 5, 2013 | 06:21 AM
Headviking's Avatar
Headviking
Code P0470
On my way to work this morning I got an engine light. Got to work used the scangaugeII to pull the codes. Got a P0470. (engine exhaust back pressure fault). Where can I find this sensor? What cost am I looking at and if anyone has a part number. Mike, any help!
Thanks
Old Mar 5, 2013 | 06:23 AM
npccpartsman's Avatar
npccpartsman
The EBP sensor is on the driver side connected to the exhaust manifold by a steel tube. Check the tube for plugging, but the code pretty much indicates it's a faulty sensor.
Old Mar 5, 2013 | 10:45 AM
Carolina Rig's Avatar
Carolina Rig
So your Scangauge actually reads the codes??
Hey, at least your Scangauge II can read the codes. Mine can't read squat, so I just use it like most everyone else to monitor different metrics.
Here's a link to a decent price on the EBP sensor. Did you hear your turbo kick out? When my EBP sensor went bad, boost went to zero and the exhuast made a drone sound.
[DPFE-6]Motorcraft Exhaust Back Pressure Sensor(EBP)-DPFE6-Ford Diesel Trucks - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Good luck.
Old Mar 5, 2013 | 11:56 AM
m-chan68's Avatar
m-chan68
John, I think the other guys above have you covered pretty good.
Old Mar 5, 2013 | 06:13 PM
Headviking's Avatar
Headviking
I found two part numbers for my truck
5C3Z-9F460-B
5C3Z-9J460-B
Does anyone know which one?
Old Mar 5, 2013 | 06:20 PM
m-chan68's Avatar
m-chan68
5C3Z-9F460-B
5C3Z-9J460-B
The one highlighted in bold red is the correct number, which changes up to a Motorcraft part number DPFE-6.
Old Mar 6, 2013 | 05:17 PM
Headviking's Avatar
Headviking
Just ordered one from powerstrokedgirl.com for $59.49 plus $9.99 shipping. A lot cheaper then the dealer ($159.99).
I did clear the code and it has not returned. I will be replacing though and cleaning out the tube.
rgvrealtor
Mar 22, 2011 12:08 PM
adamzelazowski
18
May 30, 2009 04:22 PM
triskit16
Oct 27, 2008 09:59 PM
Benny2002
Jul 8, 2007 11:25 PM
pmasley
Apr 6, 2006 10:13 PM
