84 ford yfa wiring
84 ford yfa wiring
I have an 84 ford 4.9L with a carter YFA Carb. I am looking for wiring information on the choke and the carburator stepper motor. I need the wire locations on the plug at the stepper motor connector. it is a 4 wire square connector. Two of my wires broke at the connector itself. As for the choke, I have a wire that was brittle and no indication of what it connects to in my wiring diagram. Any help would be appreciated.
84 ford yfa wiring
I'm from the older vintage carb, but I might be able to help a little. You'll need a voltmeter. The carb choke lead should be 6V and only live when the motor is on. The stepper/kicker solenoid lead should have 12V and live when the key is in the accessory (sp?) position. As far as the feedback...I'm useless.
itsnotanova
12-30-2016 12:20 PM
BBslider001
10-23-2016 09:40 PM
Hydrocarbon302
Engine Swaps
03-27-2016 10:40 AM
Smalltownboy
04-14-2015 11:56 PM
