rear end question
Old Mar 3, 2013 | 08:58 PM
FordYoungGun35's Avatar
FordYoungGun35
rear end question
my truck has a limited slip rear end, (96 5.0 4x4 f150) but the motor puts out more power than stock.. well the other day i was killlin tires and it broke posi like no bodys business and it does it everytime now.. one of my buddys was like theres no way thats a limited slip b/c it broke posi to easy.. then he asked if i had welded the rear end? whats he mean?
Old Mar 3, 2013 | 09:06 PM
Immortal_Ben's Avatar
Immortal_Ben
I am not sure what you mean by broke posi (I have a guess, but not sure).
Welding the rear end refers to welding the differential gears together. This way, both rear tires receive maximum power. It is a permanent locker, and only good for dedicated trail/bogging rigs. It is not good for street use.
Old Mar 3, 2013 | 09:13 PM
4rd1ton's Avatar
4rd1ton
When you weld a rearend the diffrential is completley solid from one wheel to the other so essentially it creates one solid axle it is sometimes common on pulling tractors but it is hard to turn because both wheeles spin at the same rate its basically useless on street vehicles. i would say you probably just have a strong motor and a good rearend because chances are its not welded
Old Mar 3, 2013 | 09:17 PM
Evan_P's Avatar
Evan_P
Your rear end is NOT a Posi unit. That's a GM thing. Your limited slip uses clutches to lock the wheels together. They have their limits though. And over time those limit's become less and less due to wear. Your is probably worn out and is getting too much power to handle it. My suggestion: Rebuild it and stop trying to be a hooligan spinning the wheels all the time. That rubber isn't cheap...
Old Mar 3, 2013 | 09:21 PM
FordYoungGun35
ahh evan your no fun haha jk grandpa owns a tire shop and had a set layin around and he let me have em to kill, but as for what i mean on pullin a posi i peeled out and instead of having 1 tire spin since my rear ends a limited slip both did.. and it wasnt even from brake torque
Old Mar 3, 2013 | 09:47 PM
Daniel5.0's Avatar
Daniel5.0
Dood I totally got a stepside F-150 with posi
Old Mar 3, 2013 | 10:08 PM
OldGrayFord's Avatar
OldGrayFord
I believe what he was trying to say is "posi" or positraction is the name for some GM limited slip units. Trac Loc is a name for Ford units at least older 9" ones. I haven't kept up on newer terminology. Typically a stock type unit functions off clutch or cone operation to achieve a suitable amount of friction to provide enough holding power under most conditions but still release to allow the wheels to spin at different speeds when needed. Like when turning a corner. A traction unit in good condition will usually spin both tires equally while going in a straight line. After enough wear they will "loosen up" or start to spin one tire like an open differential. Because the clutches can't provide enough holding power. a locker type unit is not as quiet or smooth but is a good choice for vehicles used aggressively. Welding the gears is a poor choice in my opinion even for a trail rig because you never know when it may break loose and cause rearend failure or break an axle.
Old Mar 3, 2013 | 10:20 PM
GNR22's Avatar
GNR22
Daniel5.0, no you don't.
OP, you're saying that both tires bit instead of just one, correct? If that's so, that means your limited slip unit is working correctly. And, perhaps, somebody may have rebuilt the clutch pack in it recently and shimmed them tighter so they grab better. Not positive on that last part because I wasn't there to see.
OldGrayFord, I believe these units are still called Trac Loc. And I agree that welding diffs is bad.
Old Mar 3, 2013 | 10:22 PM
Daniel5.0's Avatar
Daniel5.0
Sarcasm...missed. Stepside? Bueller?
Old Mar 3, 2013 | 10:38 PM
GNR22's Avatar
GNR22
Somebody really needs to create a sarcasm font.
Old Mar 3, 2013 | 10:55 PM
Immortal_Ben
Lol I saw the sarcasm in the "Dood" part.
Old Mar 3, 2013 | 11:20 PM
FordYoungGun35
This is as bout as simple as I can put it.. Used to with my factory 5.0 when I tried to burn out only one wheel would spin.. But now I have a motor out of a mustang which is a little more hp and when I did a burnout both wheels spun instead of just 1...
Old Mar 6, 2013 | 10:50 AM
White Max's Avatar
White Max
If you're spinning both tires, then the Trac-Lok (limited slip) diff is working as it should. If you're only spinning one tire, then it needs a rebuild (new clutches/steels).
ATE88
15
Nov 9, 2008 08:19 PM
dzzavid
Feb 6, 2007 09:28 PM
whitt6
2004 - 2008 F150
Oct 11, 2006 07:31 AM
kellar
Mar 21, 2004 02:30 AM
jhdaniels
1983 - 2012 Ranger & B-Series
May 4, 2003 10:39 PM
