Lights gremlins!
Old Mar 7, 2013 | 10:03 AM
Chris Lewis's Avatar
Chris Lewis
Headlight switch problems
replaced my headlights switch headlights were not working I get headlights but the the clearance lights slash tail push it in half way to get ta push it in half way to get tail lights but headlight shut off
Old Mar 7, 2013 | 10:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by alchemist1
Definitely know the dash lights don't come on - I checked at night.
Since my headlight switch on my 74 F-100 is a 'post C25,000' serial numbered truck.
No it is not, serial number C25,000 refers to 1976 only!
1974 serial number range: S60,001-V20,000 / 1975 serial number range: V20,001-X40,000 / 1976 serial number range: A00,001-D25,000.
D3ZZ-11654-A (replaced C5DZ-11654-A, C5TZ-11654-A, B & C) .. Headlamp Switch Kit (Motorcraft SW-1245) / Available from Ford
Applications: 1965/72 F100/1100 / 1973/75 F100/350 / 1976 F100/350 before serial number C25,000 // 1966/75 Bronco / 1976 Bronco before serial number C25,000.
And: 1965/70 Falcon / 1966 Mustang / 1970/72 Maverick/Comet and et cetera, et cetera, et cetera!
Old Mar 7, 2013 | 10:20 AM
Chris Lewis
97 with th with the headlight switch is
Old Mar 7, 2013 | 10:35 AM
alchemist1's Avatar
alchemist1
Applications: 1965/75 F100/350 / 1976 F100/350 before serial number C25,000 // 1966/75 Bronco / 1976 Bronco before serial number C25,000.
Bill, thanks for responding. So the question is - is the headlight switch for my 1977 F-150 going to work for my 74 F-100. Actually, the plugs seem identical and all seems to work fine when I swapped them out. But you're saying that the headlight switch from the 77 should NOT work in my 74?
Old Mar 7, 2013 | 10:40 AM
NumberDummy
Originally Posted by Chris Lewis
the light switches new can't get running lights and headlights the same time pulled out all the way to get headlights have to push in ways to get
It's impolite to highjack someone else's thread, especially with this gibberish that makes absolutely no sense.
Old Mar 7, 2013 | 10:44 AM
alchemist1's Avatar
alchemist1
GIB-BER-ISH! Good one Bill!
Did you see my last post/question? thanks.
Old Mar 7, 2013 | 10:53 AM
NumberDummy
So the question is - is the headlight switch for my 1977 F150 going to work for my 74 F100?
See applications below.
But FoMoCo is saying that the headlight switch from the 77 should NOT work in my 74.
D7TZ-11654-B (replaced D7TZ-11654-A) .. Headlamp Switch ~ Marked: D7TB-11654-AA (Motorcraft SW-1381).
Applications: 1976 F100/350 from serial number C25,000 / 1977/79 F100/350 // 1976 Bronco from serial number C25,000 / 1977 Bronco.
1973/79 Ford Light Truck Parts Catalog is available on a CD from hipoparts.com for 22 bucks.
Since most of y'all don't have it, we that do (mikeo0o0o0, AK FORD GUY, myself and a few others) become the messengers, type what the catalog states.
Mike & AK can scan/post pics, I'm using the catalog on FoMoCo microfiche slides.
Old Mar 7, 2013 | 10:58 AM
alchemist1's Avatar
alchemist1
D7TZ-11654-B (replaced D7TZ-11654-A) Headlamp Switch / Marked: D7TB-11654-AA (Motorcraft SW-1381).
Applications: 1976 F100/350 from serial number C25,000 / 1977/79 F100/350 / 1976 Bronco from serial number C25,000 / 1977 Bronco.
1973/79 Ford Light Truck Parts Catalog available on a CD from hipoparts.;com for 22 bucks.
Since most of y'all dont have it, we that do (mikeo0o0o0, AK Ford GUY, myself and etc) become the messangers, type what the catalog states.
Interesting. The plugs must be identical then, but something internal may be different. It plugged right in and worked (operated high/low beams and interior lights). But I want to get the right part too. I'll get back with you on this.
Old Mar 7, 2013 | 01:21 PM
fmc400's Avatar
fmc400
MSEE
Are you on drugs or something?
Old Mar 7, 2013 | 01:23 PM
alchemist1's Avatar
alchemist1
i'm still laughing from Bill's post and now yours! Hilarious!
Old Mar 7, 2013 | 08:22 PM
alchemist1's Avatar
alchemist1
So here's the deal:
The light switch that was in my 74 F100 (defective): D7TB-11654-AA (etched on part)
The light switch that was in my 77 F150 (works fine): D2AB-11654-A1A (etched on part; I think this is "A1A"
The D2AB part does work OK in my 74, but there may be issues (see previous posts by Bill / NumberDummy) with this light switch??
I realize that the above "part numbers" are not really the part numbers, per se., but just giving those as reference.
It would seem that perhaps neither part is correct for the trucks I have. I did a search for the D7TB part and it shows it should be for the 76 and up serial numbers, but it was in my 1974 truck. A search for the D2AB part shows it is for a full size Ford - a TBird, LTDII, Elite, etc., but who knows.
Old Oct 16, 2013 | 07:37 PM
alchemist1's Avatar
alchemist1
Remembering this thread and just broke out laughing. FMC400 and Bill really busted on the dude speaking jibberish! Sorry, had to revive it for a laugh!!
Old Jun 11, 2015 | 08:16 PM
  #28
BUTCH2504's Avatar
BUTCH2504
1976 F100. With radiio off,, headlights intermittingly go on and off. It does not happpen with radio on, any suggeestiions?
Old Jun 11, 2015 | 10:04 PM
  #29
Jdeshler's Avatar
Jdeshler
Damn that's a good laugh
The Terrible Blob
13
Feb 20, 2014 10:56 PM
wagonerkl
Jan 12, 2014 03:26 AM
alchemist1
Mar 4, 2013 03:00 PM
johniebomb
Jan 25, 2012 01:07 PM
jays351
Electrical Systems/Wiring
Mar 14, 2003 08:21 PM
