Help with NP205?
Old Mar 2, 2013 | 03:32 PM
low8106's Avatar
low8106
Help with NP205?
Quick question. Is swapping the yokes on the np205 as simple as removing the lock nut and sliding off the yoke? I broke my transfer case on my 77 F150 and swapped it out with one from, i was told, a 79 F150 but the new one has bigger yokes and won't bolt to my drive shaft. Please tell me I don't have to remove that heavy beast again. Thank you.
Old Mar 2, 2013 | 05:28 PM
Drac's Avatar
Drac
Save the old ones
Remove the center nut and slide right off.
Different yokes may have different seals. Just some thing to look at.
Old Mar 2, 2013 | 08:05 PM
Tinstar36's Avatar
Tinstar36
It will slide out if they are both ford np205s the splines are the Same
but if it is say a dodge then the may be problems
Old Mar 2, 2013 | 08:34 PM
low8106's Avatar
low8106
Thanks. Appreciate the help.
runner
19
Dec 6, 2017 08:20 AM
mjr46
13
Jul 27, 2016 04:29 PM
MikeFlorida
Mar 20, 2007 07:29 PM
bloomy63
Jul 26, 2006 09:09 AM
sbishop
Mar 8, 2004 06:14 PM
