Transmission Cooler Lines
Old Mar 2, 2013 | 12:36 PM
86bullnose95's Avatar
86bullnose95
I've got a leak in either the feed or return transmission cooler lines. Was wondering what type of fix anyone has done? I can get the standard metal lines and bend them to shape but I was wondering if there is a certain spot that they usually form a hole? Any ideas are welcome!
Old Mar 2, 2013 | 07:12 PM
Franklin2's Avatar
Franklin2
No usual spots. If they are not put back in their proper brackets and holders if any work is done, they can crack. And the fittings can get loose at either end. Not a common problem though. I have had them get rusty.
Old Mar 2, 2013 | 08:19 PM
86bullnose95
A friend of mine who is a very skilled mechanic said I can just replace the metal lines with hose because it isn't a pressurized line, has anyone done that?
Old Mar 2, 2013 | 08:39 PM
Ken Blythen's Avatar
Ken Blythen
There must be quite a bit of cooling provided by the steel lines, travelling from trans-radiator-trans, in addition to the cooler itself.
Old Mar 2, 2013 | 09:10 PM
ctubutis's Avatar
ctubutis
Using rubber hose in place of steel tubing is ONLY for a short-term, temporary fix until replacement steel lines can be installed. Look at a local auto parts store, they should have 4-5-6-foot lengths of straight tubing with the flared endings already installed on them.
Rubber hose fails a LOT easier.... abrasion, dry rot, sharp edges, heat, rodents, etc. can all render a rubber hose useless, and then you're spewing all your transmission fluid onto the road or, worse yet, onto the hot exhaust system and starting a fire.
There are reasons why the auto industry uses steel tubing for this...
Old Mar 2, 2013 | 09:12 PM
ctubutis's Avatar
ctubutis
BTW I would guess the most common location for leaks is where the lines attach to the transmission. Those are flare fittings, ya have to be careful there but the ends can sometimes be re-flared if you have the right tools.
Old Mar 3, 2013 | 02:15 PM
4caster's Avatar
4caster
I have metal lines from the transmission to the front of the engine and rubber hoses from the front of the engine to the radiator and external oil cooler. This setup works OK, but I do check the hoses for any wear every oil change.
Old Mar 3, 2013 | 02:21 PM
86bullnose95
I'm just going to replace both the feed and return the right way with the tubing. The routing isnt even that bad to do.
Old Mar 3, 2013 | 02:52 PM
81ChopTop's Avatar
81ChopTop
It is a pressurized line, about 40psi. If it wasn't pressurized, it wouldn't push the fluid through the cooler(s). Unhook your trans line and crank the engine over, it sprays over 10 feet.
I have to agree with Chris 110% as I found this out first hand, but not because of using hose (read on).
About 10 or so years ago I had a major trans failure (grenaded the bell housing, torque converter,drive shaft, etc..) and when the trans fluid hit the hot exhaust, it immediately started on fire. I could see the flames through the floor shifter. (The front u-joint blew apart and the driveshaft knocked out the rubber plug in the bottom of the shifter housing so I could see through).
I would advise to anyone NOT to use rubber under the vehicle. In short lengths up by the cooler is fine, but not anywhere around the exhaust.
Old Mar 3, 2013 | 03:35 PM
bashby's Avatar
bashby
You need the short sections of rubber hose up front since the trans moves around in relation to the rad.
Old Mar 3, 2013 | 06:17 PM
86bullnose95
Alright thanks for the info guys. Im just going to replace both of the lines the right way, it isnt very expensive anyways not sure why I was even thinking of cutting corners
Old Mar 3, 2013 | 08:16 PM
Franklin2's Avatar
Franklin2
I thought this also, but I have worked on a lot of factory vehicles where the steel lines went right into the radiator. So I guess depending on the situation and what was there originally, you can have short pieces of rubber to the radiator or have solid metal line the whole way.
Frdbuy8589
16
Apr 8, 2020 01:58 PM
Scoop531
Nov 24, 2013 08:28 AM
ChristopherN
Feb 18, 2012 07:58 PM
rileyruffen
2004 - 2008 F150
Mar 11, 2011 11:20 PM
