Electrical problem, please help
Old Mar 1, 2013 | 10:00 PM
vincentesq's Avatar
vincentesq
I have an 11 expedition. I installed a kenwood navigation system via I datalink maestro this morning and everything worked great! However, as I was cleaning up the wires, I probably shorted something. Now the navigation does not work anymore, I took it apart and tightened all the power and ground wires but still does not work. I check the fuse on the head unit, no problem. I checked all the fuses on the passenger compartment and all worked except #28, which is radio. However, I pulled out the fuse but it is not burned. I exchanged fuse, and it shows that the fuse on #28 is ok. Just that there is no power going to #28.
I'm assuming I shorted somewhere before the fuse box, but don't know what to do? Does anyone have any ideas ? Thank you.
Old Mar 2, 2013 | 10:37 AM
vincentesq's Avatar
vincentesq
Found the problem, fuse 39 was blown.
WootDogg
1997 - 2003 F150
15
Sep 27, 2020 04:54 PM
brians2000
2004 - 2008 F150
Apr 12, 2013 08:54 PM
ntputter17
Mar 14, 2009 10:56 PM
ncguy23
Electrical Systems/Wiring
Jul 27, 2007 03:33 PM
ghades
May 19, 2005 08:12 PM
