What has everyone used to paint/coat their running boards? If I go an ordinary 2 pack black then it will scratch up and look like crap fairly quickly I think. I want a gloss finish though, any suggestions? I plan to put a set of step plates on it to help avoid too much damage.
I was planning to use bedliner too, but I live where it's real dusty. The texture quickly gets filled with dust/dirt. I think Cowboy is in a similar climate.
I'd go gloss with clearcoat, and put down any scratches as "patina in the making"...
Didn't think of that issue. Dry is not relative where I live but would make a difference. Thanks.
Hey Aussiecowboy,
Hmmm.. Lot's of talk about dust... Can't possibly be any dustier
than Texas. We went the bedliner route on the running boards to avoid the problem you mention of them getting scratched up. We didn't want to worry about that stuff as we use our truck - the interior is sprayed as well.
The product we used is called Toff but I'm sure you have similar. You just spray it off when it's dirty/dusty.
In Montana, the vendors for bed liner also offer an upgrade with a clear poly spray over the bedliner spray. It smooths it out and gives it a little more satin finish. Really helps with the keeping clean issues associated with bed liners.
They are made to be stepped on, they will get scratched if you paint it with glossy paint unless you take your shoes off each time you get in. Or maybe you could just jump over them. If it is going to be a show truck and live its life in a garage or on a trailer then you can paint it anyway you want, but if you are going to drive it, then the bedliner is the way to go. Ben's look great, mine were beat to hell and still are, but now they have bedliner on them so that they will last longer. Personally I don't care what they look like if they will hold me up when I step on them. And they do make it easier to get in and out.
I took my boards down to a local shop that does hot bed liner and chatted with them about my project. They gave me a super cheap price if I masked off everything but the raised step treads on my boards and said that I could then take them back to my place and paint over the entire unit with my final color of gloss black.
By doing this my boards will be black but the actual surface that touches my shoe sole will be bedlined thus reduceing scratches etc.
Thats my plan, bedline the contact ribs then paint my final color over everything.
I am going to shoot the boards in gloss red like the rest of the sheet metal and install ss strips on top of the raised ribs. I bought four 12' x 1/2" hollow half oval strips at a local marine supply house (normally sold in different widths as rub rails). They are drilled for oval headed screws every 6". I have not yet decided if I will leave the screw heads exposed or tig and then polish the screw heads making them blind. Another option that I considered was boneyard hunting for some of the ss strips that long roofs (station wagons) had on top of the roof. I think that 80's GM might be good donors but I did not go that route. I believe that the stock thickness on my ss strips are probably thicker than the strips coming off a long roof. I am not at all concerned about denting the strips that I have.
My stock F-250 boards are not replaceable as far as I know. They have no rust but they sure got bent up. I straightened them up but they still have enough ripples and dings that I need to do something before I finish them. I'm wondering if I can use a little filler on them, then have them bed lined and finish with the stainless strips over the raised step treads.
I've been giving this a lot of thought. I've decided I'm gonna powder-coat them black, and put HD 3/4 inch anti-skid tape on the raised bed threads to minimize any scratches.
